NEED A LISP FOR A OBJCET IS ALIGNED TO LINE OR NOT...
archana96
Message 1 of 11
archana96
HI GUYS I HAVE A PROBLEM WITH ALIGNING OBJECTS SAME LINE.. SOMETIMES IT'S NOT ALIGNED BUT IT SHOWS LIKE SAME ALIGNMENT.
Replies (10)
Message 2 of 11
-didier-
Bonjour @archana96
You do not say enough in your question to be effectively assisted.
What kind of object?
And aligned that what kind of object?
It is very different from aligning a line on a line or aligning a block (geometry?) on a polyline with multiple vertices.
Amicalement
Éternel débutant.. my site for learning : Programmer dans AutoCAD
DA
Message 3 of 11
Kent1Cooper
If you are talking about two straight things, and you want to know whether or not they are aligned in the same direction, i.e. whether or not they are parallel, one thing you can do is to use the BI command defined in BISECTOR.lsp, >here<, and pick on the two objects.  It will draw an XLINE BIsecting the angle between them if they are not parallel, and if they are parallel, it will draw it halfway between them and parallel to both, and it will tell you they're parallel and that it's doing that.  So that can be your "report" that they are aligned in the same direction.  It works on top-level and nested objects, so for example, if you want to check whether a Block is aligned with a Polyline line segment, if there's a piece of the Block that runs in the direction you want to check, you can pick on that nested object and on the relevant segment of the Polyline.
[Of course the parts of the command that determine whether things are parallel could be pulled out into a simpler command that would report on that, without drawing the XLINE.]
If that's not what you mean by the "aligned or not" question, explain in more detail.  [For example, not just aligned in direction, but also coinciding as you could make them do with an ALIGN command?]
Kent Cooper, AIA
Message 4 of 11
-didier-
Bonjour
I think we have to wait for  @archana96 to answer us by sending us an example (dwg) in which we will see the actions to be carried out.
Please put in the two cases, one before the program, the other after.
Amicalement
DA
Message 5 of 11
Kent1Cooper
@-didier- wrote:
....  @archana96 .... Please put in the two cases, one before the program, the other after.
That's part of what we need more explanation about: There may be no "after" that's any different from "before," if all they want is to know whether something is "ALIGNED TO LINE OR NOT."  That "OR NOT" wording sounds to me like maybe they want only a "status report," but not necessarily to change anything.
Kent Cooper, AIA
Message 6 of 11
archana96
for your reference, i attached the file
Message 7 of 11
Sea-Haven
This is like a pre start to this  https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/get-dimensions-for-all-poly-lines-wi...
The internal objects are plines and hatch so why have you not used a lisp to make sure they are drawn correct, refer also the the other dwg "Work1" where the objects are not aligned to an edge but can be offset in 2 directions. Picking lines gets there angle so making rectangs is correct.
Message 8 of 11
archana96
i have many rectangular   for  checking taking too much of time. for fast work i need a lisp so please help sir,
Message 9 of 11
Kent1Cooper
Given that you are starting with the objects but not the alignment lines, I see a potential problem.  Exaggerating the difference for illustration, in a vertical-position comparison:
If you have two at one level and two at another, how can a routine decide which two are at the correct alignment and which two are off?  Should the yellow line become your red line, and should the objects that touch the magenta line be flagged as being misaligned, or the other way around?
Kent Cooper, AIA
Message 10 of 11
archana96
I only check with one line. if the rectangular is touched pallor to  the line it's ok, if any object is not touched or over crossed the line needs to show the different color
Message 11 of 11
Kent1Cooper
@archana96 wrote:
I only check with one line. ....
Does that mean that the lines to check against exist in the drawing already?  They are not in the "before" part of your sample drawing.
Kent Cooper, AIA
