I haven't seen one of these contraptions anywhere, but I am imagining it.
The goal is that by tightening the vang (from either side of the boat), not only do you pull the boom down but also pull it forward to optimize the sail shape and outward position mainly on a run. Conventional vangs attached to the base of the mast don't pull the boom forward.
Rather than trial and error by drawing the thing a number of times with the boom in or out, I want to calculate the height above the deck. I am pretty sure that the XY force vector is the bisector of the two legs of the vang, but calculating the Z will indicate to me the relative downward pull that the vang will exert on the boom at its point of attachment to the boom. With this daydream design, I am assuming that the closer hauled the sail (boom being almost midships) that the downward pull will be the minimum, which is what you want when sailing upwind because the mainsheet should control the downward pull in that condition.
Anyone got any functions that will help me calculate the Z for various boom angles and tightness on the vang?
My premonition is that the force directions are simple (x y z) vectors and that the Z value is just a matter of applying the sine of the vertical part of the vector. But I could spend days on this and spin myself in circles (just like many sailors do on the water after they have fouled another boat.) I would like to build and use it (if it mathematically works) before the end of the racing season, just three weeks away. Even better for the next races this coming Friday.
Now it's probably not that important because I lapped the rest of the fleet twice in the last race. I'm not a sore loser, but winning is fun.
For those of you who have read this far and are familiar with yacht racing rules, for fun I suggested to the committee that the 360° penalty is too severe and should be cut in half.😆
John F. Uhden
