Name line with it nearest grid axis name
the_ameral
Message 1 of 10
the_ameral
Iwant to name every line with the grid nearest it
Or away to do this
"Ican give ahint
define every grid with it name
Then find the rotation of line if horizontal find axis near and parallel  to it
And the nearest start and end of line grid
Replies (9)
Message 2 of 10
the_ameral
Message 3 of 10
Valentin_CAD
@the_ameral ,
There may be a LISP, consider this link from the Visual LISP, AutoLISP and General Customization forum:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Message 4 of 10
the_ameral
I USE AUTOCAD NOT CIVIL3D
Message 5 of 10
hosneyalaa
Please attach an example drawing
Explain what is required
Message 6 of 10
the_ameral
Message 7 of 10
the_ameral
Message 8 of 10
Sea-Haven
Just ideas move text so is mid on line at top left etc, then just pick a point on line at segment, you can then find say the "B" line so thats 1 variable required, then do a intersect with and compare pts find the + and - near point again get the value so 2 and 3. Use say xline for intersect with. This is using a point select not a red line can draw red line and text. Need a global answer as grids may start at say A1 F2-2 and so on.
Message 9 of 10
the_ameral
I cant get it
Message 10 of 10
hak_vz
It would be relatively easy to do if your drawing would be organized in layers. The way it now stands it's hard to do. One option is to implement function to automatically name horizontal and vertical elements of the grid. Naming of the lines on the grid would then be taken from layer names.
Miljenko Hatlak
