My Lisp Routines Stopped working
dkerns
dkerns
After a Windows update my lisp routines stopped working, keep getting this error message in autocad.Error message.JPG
kpblc2000
Did you load ActiveX extension& I mean (vl-load-com) instruction
And what will return (vlax-dump-object (vlax-get-acad-object)) ?
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
Алексей Кулик aka kpblc | Aleksei Kulik aka kpblc Facebook | LinkedIn
autolisp.ru
Техническая поддержка программистов Autodesk в СНГ
Библиотека пользовательских lisp-функций | Custom Lisp-function library
dkerns
kpblc2000
First way. You load (vl-load-com), and then any vl-*, vla-* and vlax-* function works correct. In this case just add (vl-load-com) to any lisp you use.
Second. Executing (vl-load-com) does nothing, you can't dump (vlax-get-acad-object), because it returnl null pointer. In this case i see only one way to solve problem: fully reinstall AutoCAD and all Autodesk products.
autolisp.ru
dkerns
Installed Service Pack and issue went away.
kpblc2000
Hmmm.. I thought you already installed all updates to AutoCAD (and what version is?). And i think my post is not solution - it doesn't solve your problem. Because of this i'll uncheck solution, sorry. Your post is solution, not mine.
autolisp.ru
