Multiple polyline ltscale???
DC-MWA
DC-MWA
Hi gurus,
I am working on a little lisp that manipulates ltscale of all polylines on a certain layer.
I have the parts that set them all to 1.  I'm trying to set them all to a variable value instead of 1.
(setq dscl_math (/ (atoi lay_name_scale) (getvar "dimscale")));;variable
;;;;this sets to 1, instead of 1 i need to use "dscl_math"
((lambda (/ ss i)
(if (setq ss (ssget "x" (list (cons 0 "LWPOLYLINE") (cons 8 new_layer))))
(repeat (setq i (sslength ss))
(entmod (append (entget (ssname ss (setq i (1- i)))) '((48 . 1.))))
(princ)
I'm keep screwing it up??
dc
DC-MWA
This needs more explanation...
I need to get the ltscale of each polyline and mutilpy by the variable and then set the ltscale of each polyline to that new value.
I hope that makes sense.
dlanorh
Try this :
(setq obj (vlax-ename->vla-object (ssname ss (setq i (1- i)))))
(vlax-put-property obj 'linetypescale (* (vlax-get-property obj 'linetypescale) your_val))
);end_repeat
);end_if
your_val is the value you want to multiply by as a real number
Oops missed post 2, amended above code
I am not one of the robots you're looking for
DC-MWA
Thank you. That worked perfectly!!!
