Multileader style Name
MShoesmith
Message 1 of 15
MShoesmith
I would like to create a quick selection set of a Multi-leader style (named "ABC").
I am struggling to do this and i understand that you need to drill into the Dictionary to obtain the style name.
I am wanting to select the Multileader style in the current space and this is what i have so far...
(if (setq ss (ssget "_A" (list '(0 . "MULTILEADER")(if (= 1 (getvar 'cvport)) (cons 410 (getvar 'ctab)) '(410 . "Model")))))(sssetfirst nil ss))
 If there is a way of adding the Multileader style  name to this, i would be very grateful for any help.
Ta
Shoey
Shoey
Replies (14)
Message 2 of 15
Sea-Haven
Message 3 of 15
MShoesmith
Cheers Pal.
So i have tested the code at the link and the code does work when replacing a Multileader style.
However, i would like the selection to go into a selection set.
Code is show below but comes with a "error bad argument type" message.
Again, any help appreciated
(defun c:test  (/ sel int obj)
 (if (setq sel (ssget "_A" (list '(0 . "MULTILEADER")(if (= 1 (getvar 'cvport)) (cons 410 (getvar 'ctab)) '(410 . "Model")))))
   (repeat (setq int (sslength sel))
     (setq obj (vlax-ename->vla-object (ssname sel (setq int (1- int)))))
     (if (eq (vla-get-stylename obj) "ABC")
       (sssetfirst nil obj)
 (princ)
Shoey
Message 4 of 15
komondormrex
hey, somewhat corrected
(defun c:test  (/ mleader_sset mleader_sset_filtered)
 (setq mleader_sset_filtered (ssadd))
 (if (setq mleader_sset (ssget "_A" (list '(0 . "MULTILEADER")(if (= 1 (getvar 'cvport)) (cons 410 (getvar 'ctab)) '(410 . "Model")))))
   (foreach mleader (vl-remove-if 'listp (mapcar 'cadr (ssnamex mleader_sset)))
     (if (= "ABC" (vla-get-stylename (vlax-ename->vla-object mleader)))
     	(ssadd mleader mleader_sset_filtered)
 (sssetfirst nil mleader_sset_filtered )
 (princ)
Message 5 of 15
MShoesmith
Thank you very much. After testing, it does what i require.
I will study the code you have provided and learn from it.
Kind regards
Shoey
Message 6 of 15
WeTanks
In what situation is it useful?
Why not use it?
We.Tanks
A couple of Fusion improvement ideas that could your vote/support:
図面一括印刷
Message 7 of 15
komondormrex
in selecting all mleaders, regardless of their styles
Message 8 of 15
MShoesmith
Select similar selects all Multi-leaders.
I could use QSELECT and select Multi-leader and style that way.
Both of these can use individually in dwg files.
The code given will select all Multi-leader styles in one-click. (Instead of several clicks in QSELECT).
But main reason is that i can use the code via a script when changing layer of the selected Multi-leader style in a batch of drawings.
Shoey
Message 9 of 15
WeTanks
thanks for the reply.
I understand.
but, This Lisp can only choose ABC,
Others cannot be selected.
It feels a bit limiting.
We.Tanks
図面一括印刷
Message 10 of 15
ВeekeeCZ
@komondormrex @MShoesmith @WeTanks
you guys explore SELECTSIMILARMODE if you're running it in the default setting.
And yes, SELECTSIMILAR can be used in scripts.
Message 11 of 15
MShoesmith
Thanks for that.
I overlooked the SELECTSIMILARMODE for selecting Multi-leader styles. (object style was not checked in the settings for me).
I will look into using that and SELECTSIMILAR in a script too.
But the code provided is fine too.
Regards
Shoey
Message 12 of 15
komondormrex
so did i. too many variables to remember)))
Message 13 of 15
ВeekeeCZ
Well, if that's the case, maybe your vision serves you better. 😉
Message 14 of 15
komondormrex
in case
(defun select_mleader_style  (mleader_style_list / mleader_sset mleader_sset_filtered)
   		(if mleader_style_list
   			  (if (member (vla-get-stylename (vlax-ename->vla-object mleader)) mleader_style_list)
			(setq mleader_sset_filtered mleader_sset)
 	(princ)
(select_mleader_style nil) - to select all mleaders
(select_mleader_style '("ABC" "BCD")) - to select all mleaders styled with "ABC", "ВCD" styles
Message 15 of 15
WeTanks
You are Great!
This is very convenient!
どうもありがとうございました。
We.Tanks
図面一括印刷
