Multi text positions (Coordinates) on lisp
Message 1 of 9
Hello everyone
I have a big problem on positioning (can be coordinate but i can't) objects on lisp. And I think that it will be easier if use coordinates but I cant get how to add coordinates specially on texts. So I'm using the polar function for now and I attached picture, .lsp file and cad file. If there is any suggestion that will be helpful.
Note: The justify of texts will be shown on cad file
Thanks in advance
Sincerely,
Enkhtaivan Temuulen
New Mongol Kosen
Replies (8)
Message 2 of 9
ВeekeeCZ
Some possible things to do with text:
(setq strlot "a-")
(command "text" "j" "tl" POINT2 0 "a-")
(command "text" "j" "tl" POINT2 0 "%%C")
(command "text" "j" "tl" POINT2 0 (strcat strlot "%%C"))
BTW. Did you try to use MULTILEADER with block style for that? I'm not sure if that's possible, but some fella from Autocad's forum might help you to figure out. Then I would be so much easier to work with. Mleaders are quite powerful entities.
Message 3 of 9
dbhunia
Try this.......
Roughly modified your code.... hopefully you can manage the rest.....
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
Message 4 of 9
Sorry for late feedback. Havent tried the mleader  and i have no experience about block style yet. But thanks, I'll try it when I started using block styles on lisp.
Message 5 of 9
Sorry for late feedback. I have tried your code and its almost done. There is only one problem that I cant recognize. When choosing the direction (as shown in attachments: picture1, picture2) some "distance" follows around mouse cursor, I've tried it 2 variants. Variant number one (shown picture1) is much lower "distance"(its bit hard to use, zooming and set lower "distance") and the result one comes (the success result). And the variant number two (shown picture2) is bit higher "distance" from variant one. Unfortunately it results irregular text coordinates as the result two (shown picture3). If success the higher distance (setting direction without zooming) it will be done completely.
Message 6 of 9
Lisp file
Message 7 of 9
dbhunia
Try with Manipulation of "OSMODE" setting.......
Debashis Bhunia
Message 8 of 9
Done. That was the solution. My osmode set into random value somehow. I changed it to <0>. And problem solved. Thanks for your advice.
Message 9 of 9
royner.tineoreyes
Thanks, it help me too
