Multi Leader Object Text Color
Is there anyway to change an existing Multi leader object "Text Color" (annotation color) through some program without changing Multi Leader Style.?
I have tried by creating another Multi leader as i required and applied Match Properties command, but that is only changing Style of original Multi Leader object and leaving Font and Color unchanged.
This is Existing Multi Leader Object in Drawing
This is after applying Match Properties Command (the source multileader is having font:simplex, color:yellow, but those properties not transfering here)
 This is actually my requirement
please help.
ВeekeeCZ
This routine will set color of mleader text for multiple selection.
(vl-load-com)
(defun c:MLeaderTextColor ( / col ss obj txt x y)
  (if (and (setq col (getint "\nText color number: "))
           (setq ss (ssget '((0 . "MULTILEADER"))))
    (repeat (setq i (sslength ss))
      (setq obj (vlax-ename->vla-object (ssname ss (setq i (1- i))))
            txt (vla-get-TextString obj)
            txt (vl-string-trim "{}" txt))
      (foreach e '("\\C" "\\c")
        (while (and (setq x (vl-string-search e txt))
                    (setq y (vl-string-search ";" txt x)))
          (setq txt (strcat (substr txt 1 x)
                            (substr txt (+ 2 y))))))
      (vla-put-TextString obj (strcat "{\\C" (itoa col) ";" txt "}"))))
  (princ)
It is working perfect.
BeekeeCZ >>>>>Thank you very much boss. I really admire your programming skills.
thanks a lot.
Smiley Happy
