MTXT formatting
MTXT formatting
rolisonfelipe
MTXT formatting
rolisonfelipe
I am need to format this line of top center  "TC ", for bottom center  "BC ", on automatic insertion
        (setq t_str (strcat "DISTANCE: " (rtos seg_len 2 3) "m\\P Az:" (vl-string-subst "%%d" "d" (angtos alpha 1 4))))
        (setq t_str (strcat "CURVE01"  "m\\P AC:" (angtos (- pi (* 2 alpha)) 0 4) "%%d" "d" "m\\P TG:""m\\P RAY:" (rtos rad 2 3) "m\\P DISTANCE:" (rtos seg_len 2 3)"m."))
cadffm
Take a MTEXT "before"
check the entity data
(setq before (entget(setq ename (car(entsel))) '("*")))
(vlax-dump-object (vlax-ename->vla-object ename))
Edit this MText BY HAND and check the data again - help yourself
(setq after (entget ename '("*")))
Sebastian
rolisonfelipe
That set of variables she would enter at that point...
 (mapcar '(lambda (pr val) (vlax-put nw_obj pr val))
        ;(list 'AttachmentPoint 'Insertionpoint 'Height 'DrawingDirection 'StyleName 'Layer 'Rotation 'Width)
        ;(list att_pt m_pt (getvar 'textsize) 5 "ELEV_ARIAL_1" "DIMENSIONS" t_ang t_width)
        (list 'AttachmentPoint 'Insertionpoint 'Height 'DrawingDirection 'Rotation 'Width)
        (list att_pt m_pt (getvar 'textsize) 5 t_ang 0.0)
      );end_mapcar
    );end_repeat
  );end_for
(mapcar 'setvar sv_lst sv_vals)
 (if (and c_doc (= 8 (logand 8 (getvar 'UNDOCTL)))) (vla-endundomark c_doc))
  (princ)
dbhunia
use ONE OF this....
(setq att_pt 1);for TL
(setq att_pt 2);for TC
(setq att_pt 3);for TR
(setq att_pt 4);for ML
(setq att_pt 5);for MC
(setq att_pt 6);for MR
(setq att_pt 7);for BL
(setq att_pt 8);for BC
(setq att_pt 9);for BR
      );end_mapcar
    );end_repeat
  );end_for
  (princ)
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
rolisonfelipe
Thanks again... Smiley Happy
Fantastic! was of first!
I'm going to turn Mr. Polyline in a little bit.
rolisonfelipe
You'd know how to tell me, why DEFUN PIncert command doesn't load ....And draws the notable lines...
(vl-load-com)
(DEFUN C:TG () (C:ROAD))
(defun c:ROAD ( / *error* c_doc spc sv_lst sv_vals nw_style nw_font htx ss o_type pr
  pt_start pt_end seg_len seg_bulge rad alpha m_pt t_ang t_str
  nw_obj ll ur att_pt t_width )
 (defun *error* ( msg )
  (if (not (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*EXIT*")) (princ (strcat "\nOops an Error : " msg " occurred.")))
  (princ)
 );end_*error*_defun
  (defun PIncert ( / )
    (command "._line" pt_start pt_vtx "")
    (command "._line" pt_vtx pt_end "")
    (command "._line" pt_start pt_cen "")
    (command "._line" pt_cen pt_end "")
  (setq c_doc (vla-get-activedocument (vlax-get-acad-object))
        spc (if (= 1 (getvar 'cvport))
                (vla-get-paperspace c_doc)
                (vla-get-modelspace c_doc)
            );end_if1
        sv_lst (list 'osmode 'cmdecho'textstyle 'TEXTSIZE 'clayer);;system variable names list
    sv_vals (mapcar 'getvar sv_lst);;get current values
  );end_setq1
  (cond ( (null (tblsearch "LAYER" "TGCOTA")) (vlax-put (vla-add (vla-get-layers c_doc) "TGCOTA") 'color 7)))
  (cond ( (null (tblsearch "STYLE" "DIM"))
          (setq nw_style (vla-add (vla-get-textstyles c_doc) "TGCOTA")
                nw_font (strcat (getenv "systemroot") "\\Fonts\\Arial.ttf")
          );end_setq2
          (mapcar '(lambda (pr val) (vlax-put-property nw_style pr val))
            (list 'FontFile 'Height 'ObliqueAngle 'Width 'TextGenerationFlag)
            (list nw_font 0.0 (/ (* 0.0 pi) 180) 1.0 0.0)
          );end_mapcar1
  );end_cond1
  ;(mapcar 'setvar sv_lst (list 0 0 1 90.0))
  (initget 6)
  (setq htx (getreal (strcat "\nSpecify text height <" (rtos (getvar "TEXTSIZE")) "> : ")))
  (if (not htx) (setq htx (getvar 'TEXTSIZE)))
  (mapcar 'setvar sv_lst (list 0 0 "TGCOTA" htx "TGCOTA")); give them the values you want
 (vla-startundomark c_doc)
  (prompt "\nSelect polylines : ")
  (while (null (setq ss (ssget '((0 . "LWPOLYLINE")))))
    (princ "\nSelection is Empty. Selected Items were not LWPolylines!")
  );end_while
(setq
    SS
    (ssget
      '((-4 . "<OR")
        (-4 . "<AND")
          (0 . "POLYLINE")
          (-4 . "<NOT")
            (-4 . "&") (70 . 126)
          (-4 . "NOT>")
        (-4 . "AND>")
        (0 . "LWPOLYLINE,ARC")
        (-4 . "OR>"))
    n -1
  (cond
    (js
      (setq
        AcDoc (vla-get-ActiveDocument (vlax-get-acad-object))
        Space
          (if (= 1 (getvar "CVPORT"))
            (vla-get-PaperSpace AcDoc)
            (vla-get-ModelSpace AcDoc)
        nb 0
      (cond
        ((null (tblsearch "LAYER" "Info ARTDB des Arcs"))
          (vlax-put (vla-add (vla-get-layers AcDoc) "Info ARTDB des Arcs") 'Color "5")
      (setq
        oldim (getvar "dimzin")
        oldlay (getvar "clayer")
        a_base (getvar "ANGBASE")
        a_dir (getvar "ANGDIR")
      (setvar "dimzin" 0) (setvar "clayer" "Info ARTDB des Arcs")
      (setvar "ANGBASE" 0) (setvar "ANGDIR" 0)
      (repeat (sslength js)
        (setq
          ename (ssname js (setq n (1+ n)))
          obj (vlax-ename->vla-object ename)
          pr -1
          nb 0
        (setq typ_obj (vla-get-ObjectName obj))
        (if (eq typ_obj "AcDbArc")
          (progn
            (setq
              pt_start (vlax-get obj 'StartPoint)
              pt_end (vlax-get obj 'EndPoint)
              pt_cen (vlax-get obj 'Center)
              rad (vlax-get obj 'Radius)
              alpha (* (vlax-get obj 'TotalAngle) 0.5)
              seg_len (vlax-get obj 'ArcLength)
              pt_vtx (polar pt_cen (+ (vlax-get obj 'StartAngle) alpha) (+ rad (* rad (1- (/ 1 (cos alpha))))))
              nb (1+ nb)
            (PIncert)
          (repeat (fix (vlax-curve-getEndParam obj))
            (setq
              dist_start (vlax-curve-GetDistAtParam obj (setq pr (1+ pr)))
              dist_end (vlax-curve-GetDistAtParam obj (1+ pr))
              pt_start   (vlax-curve-GetPointAtParam obj pr)
              pt_end (vlax-curve-GetPointAtParam obj (1+ pr))
              seg_len (- dist_end dist_start)
              seg_bulge (vla-GetBulge obj pr)
            (if (not (zerop seg_bulge))
              (progn
            pt_start (vlax-curve-getpointatparam obj pr)
            pt_end (vlax-curve-getpointatparam obj (1+ pr))
            seg_len (- (vlax-curve-getdistatparam obj (1+ pr)) (vlax-curve-getdistatpoint obj pt_start))
            seg_bulge (vla-getbulge obj pr)
            rad (if (zerop seg_bulge) 0.0 (abs (/ seg_len (* 4.0 (atan seg_bulge)))))
            alpha (if (zerop seg_bulge) (angle (trans pt_start 0 1) (trans pt_end 0 1)) 0.0)
            m_pt (vlax-curve-getpointatparam obj (+ 0.5 pr))
            alpha (angle '(0 0 0) (vlax-curve-getfirstderiv obj (+ 0.5 pr)))
            t_ang alpha
            nb (1+ nb)
            (PIncert)
      );end_setq
      (if (< (/ pi 2) t_ang (* (/ pi 2) 3)) (setq t_ang (+ t_ang pi)))
      (if (= seg_bulge 0.0)
        (setq t_str (strcat "Az:" (vl-string-subst "%%d" "d" (angtos alpha 1 4)) "\\P DISTANCE:" (rtos seg_len 2 3) "m" ))
       );end_if
      (setq nw_obj (vla-addmtext spc (vlax-3d-point m_pt) 0.0 t_str))
      (vla-getboundingbox nw_obj 'll 'ur)
      (setq ll (vlax-safearray->list ll)
            ur (vlax-safearray->list ur)
            t_width (+ (* (distance ll ur) (cos (angle ll ur))) 5.0)
      );end_setq
      (if (>= t_width seg_len)
        (setq att_pt 5
              t_width seg_len
        );end_setq
        (setq att_pt 8
              m_pt (polar m_pt (+ t_ang (/ pi 2)) (* (getvar 'TEXTSIZE) 8))
        );end_setq
      );end_if
        ;(list att_pt m_pt (getvar 'TEXTSIZE) 5 "TGCOTA" "TGCOTA" t_ang t_width)
        (list att_pt m_pt (getvar 'TEXTSIZE) 5 t_ang 0.0)
      );end_mapcar
    );end_repeat
  );end_for
  (princ)
);end_defun
rolisonfelipe
As scheduled.....
(strcat "{\\fARIAL|b0|i0|c0;\\C7"
"CURVA " (itoa nb)
"\\P AC:" (vl-string-subst "%%d" "d" (angtos
(- pi (* 2 alpha)) 1 4))
"\\P TG:" (rtos (distance pt_start pt_vtx) 2 3)
"m.\\P Raio:" (rtos rad 2 3)
"m.\\P Distância: " (rtos seg_len 2 3) "m" "}" )
(angle pt_start pt_end) ) )
How to program to stay like this, as in Picture 02
