-mtext Help.
-mtext Help.
ed.rci.rogers
-mtext Help.
ed.rci.rogers
Hi
I have this commands written in excel:
-mtext 320637.6047,4839821.0842,10.1438 @ TPZ\P 9CM  %%C\P= 1.2m
-mtext 320640.6351,4839817.2578,11.0577 @ TPZ\P 8CM  %%C\P= 1.2m
-mtext 320640.0863,4839822.4595,10.2250 @ TPZ\P 4CM  %%C\P= 1.2m
-mtext 320639.3088,4839822.1849,10.1675 @ TPZ\P 4CM  %%C\P= 1.2m
-mtext 320638.3527,4839821.9714,10.1570 @ TPZ\P 4CM  %%C\P= 1.2m
Is there a way to insert the height and style of text in this commands?
Thanks for the help.
john.uhden
The text strings appear so short.  Why not just use Text?
John F. Uhden
ed.rci.rogers
Hi this is only a sample I have about 400 lines to code with the same situation.
Sorry for not stating what the actual situation is.
devitg
You have to state , both , after first point , then you have to state the second point
-mtext x1,y1,z1 H 50 S standard x2,y2,z2 nnnn
ed.rci.rogers
Thanks for the help. I was able to use the Height (H) portion  but not the Style (S) but tthat's fine.
