MText Contents Problem
neam
Message 1 of 8
neam
Hi everyone
I wrote a code with the help of subroutines to get information from the curves.
when I select som of object, the code works correctly.
but when I select all objects, mtext is created, but its content is empty.
when I move the objects to 0,0,0 it works.
What is the cause of this problem?
Thank you for guiding me.
Replies (7)
Message 2 of 8
hosneyalaa
@neam
Is thatthe problem
Message 3 of 8
neam
Hi hosneyalaa:
thank you for attention.
problem is in creating mtext, not in the table.
Message 4 of 8
hosneyalaa
It works fine for me
Do Have a picture of where the problem is , So I focus on it
Message 5 of 8
Sea-Haven
This is part 2 of the prior request trying to find post1.
Its not a good idea to start new posts rather keep asking at original post if you have problems.
Found Solved: Create table from list - Autodesk Community - AutoCAD
Message 6 of 8
neam
You are absolutely right.
The previous post was related to lists and tables, which was resolved.
This post is a problem in Contents of mtext.
I thought I should bring it up in a new post.
Please accept my apologies again.
Message 7 of 8
neam
In the attachment file in the current Zoom, Lisp did not write mtext.
When you get zoom extend, Lisp works correctly at 0,0.
Message 8 of 8
ВeekeeCZ
The issue is that the content is simply too long.
If the length exceeds 250 chars, it splits the definition into multiple 3 codes by 250 chunks.
Rather use the command method to create MTEXT that long.
Read about code 3 here
https://help.autodesk.com/view/ACD/2024/ENU/?guid=GUID-5E5DB93B-F8D3-4433-ADF7-E92E250D2BAB
