moving several block attributes together
mruPRQUJ
mruPRQUJ
I wonder if one lisp can be created to move several block attributes together. For example, they will be moved up one line or two lines. There are two blocks in attached file, one is BCH-X-BORD-REFF-FULL_D-size with attributes, another one is BCH-X-BORD-REFF-FULL_B-size without attributes. Please note, there is one block in a DWG at a time, they are not in the same DWG at the same time. Thank you very much in advance. 🙂
Sea-Haven
Your sample has 1-6 as example so if moved up what would be row 1 0 up 2 would be -1 ?
Are the attributes linked to an attribute in say a title block per layout ? I ask as I have read layouts and make a dwg index. It reads certain attributes then fills in a Dwg index.
mruPRQUJ
Hi, the attributes are not linked.if one reference is needed to add after #1,  moving #2 - #6 up one line, I need to move 6 to 7, and then 5 to 6. One by one, drawing number and title are separate attributes. If two references are needed to add, and then moving up two lines. Nothing are linked to drawing index. Just modify the block attributes. It takes a little longer time to do it, thanks a lot! 🙂
