MOVE POLYLINE TO SPECIFIC POINTS
Message 1 of 15
IS THERE ANY CODE TO MOVE POLYLINE ,BY USING SPECIFIC POINTS , IWANT TO MOVE THE POLYLINE ,TO BELOW SHOWN POINTS , SOME TIMES
POINTS MAY BE IRREGULAR,
Accepted solutions (3)
Replies (14)
Message 2 of 15
pendean
Community Legend
Community Legend
Or just draw a new PLINE at those points and delete the "old" one?
Message 3 of 15
Kent1Cooper
@Anonymous wrote:
IS THERE ANY CODE TO MOVE POLYLINE ,BY USING SPECIFIC POINTS ....
I agree that it may be easier to just draw a new one and delete the old one.  But in either case, how would the code be provided with those points?  Should it ask the User for them?  [If so, the User may as well just draw the Polyline manually instead.]  Are they in a list of points stored in a variable?  Are they coming from an external file?  Are they related to some other existing object(s) in the drawing?  Etc.
Kent Cooper, AIA
Message 4 of 15
polyline contains object data, and it can not be deleted,EDIT ONLY
POINTS DOES NOT COTAIN ANY DATA, JUST I WANT TO MOVE THE POLYLINE ,
JUST NEED TO ASK USER POSITION OF 1ST VERTEX, 2ND VERTEX ..............OF SELECTED POLYLINE
Message 5 of 15
ВeekeeCZ
Try to redraw the polyline with this routine...
(vl-load-com)
(defun c:plinefrom ( / ss ed enlast ef)
  (if (and (princ "\nSelect pattern polyline: ")
	   (setq ss (ssget "_+.:E:S" '((0 . "LWPOLYLINE"))))
	   (= 1 (sslength ss))
	   (setq ed (entget (ssname ss 0)))
	   (setq enlast (entlast))
	   (princ "\nDraw new polyline: ")
	   (progn
	     (command "_.PLINE")
	     (while (> (getvar 'CMDACTIVE) 0) (command PAUSE))
	     (if (not (equal enlast (entlast)))
	       (setq ef (entlast))))
      (progn
	(entmod
	  (setq ed (vl-remove-if '(lambda (x) (vl-position (car x) '(40 41 42 10 90 91))) ed)
		ed (append ed (vl-remove-if-not '(lambda (x) (vl-position (car x) '(40 41 42 10 90))) (entget ef)))))
	(entdel ef)
  (princ)
Message 6 of 15
Kent1Cooper
Another [and shorter] way to accomplish the last part of that, if there are no arc segments or widths involved -- just impose the new Polyline's coordinates as a VLA Property on the original:
(vl-load-com)
(defun c:plinefrom ( / ss obj enlast ef)
  (if
    (and
      (= 1 (sslength ss))
      (setq obj (vlax-ename->vla-object (ssname ss 0)))
      (progn
        (command "_.PLINE")
        (if (not (equal enlast (entlast))) (setq ef (entlast)))
      ); progn
    ); and
    (progn ; then
      (vla-put-Coordinates obj (vla-get-Coordinates (vlax-ename->vla-object ef)))
      (entdel ef)
    ); progn
  ); if
  (princ)
); defun
Kent Cooper, AIA
Message 7 of 15
THANKS FOR RESPONSE
ITS WORKING FINE
Message 8 of 15
mihai_bantas
Hello everyone, please help me with a suggestion... is it possible for the selection to apply a block???
(setq ss (ssget "_+.:E:S" '((0 . "LWPOLYLINE,BLOCK"))))
Thanks in advance.
Message 9 of 15
ВeekeeCZ
Thanks in advance.
No.
Start a new thread and explain what is your goal. Possibly post a dwg sample.
Message 10 of 15
mihai_bantas
hello BeekeeCZ, what I want is to select a block that contains several polylines and move them along a certain polyline (let's say I want a quick georeferencing along a certain polyline or polygon).
I also attach an explanatory file.
Thanks.
Message 11 of 15
mihai_bantas
hello everyone, I'm back with my problem related to the adaptation of the above code.
I kept trying to modify it... but I can't figure out where I'm going wrong.
Thank you in advance
(vl-load-com)
  (if (and (princ "\nSelect BLOCK:")
	   (setq ss (ssget "_X"'(0 . "INSERT")))
		   (setq p1 (getpoint "POINT1:"))
		   (setq p2 (getpoint "POINT2:"))
		   (setq p3 (getpoint "POINT3:"))
		   (setq p4 (getpoint "POINT4:"))
	   (= 1 (sslength ss))
	   (progn
		 (command "_.PLINE")
      (progn
	(entmod
	(entdel ef)
  (princ)
Message 12 of 15
ВeekeeCZ
Ok, to clear things up.
THE METHOD USED IN THIS CODE IS NOT APPLICABLE TO BLOCKS AT ALL.
It's nowhere close to being as simple as that.
Message 13 of 15
mihai_bantas
ok, then how can I modify the code to move multiple objects (line, polyline, circle, etc.) based on a single polyline?
Thanks for the info and time
Message 14 of 15
ВeekeeCZ
Do you know the ALIGN command?
Message 15 of 15
mihai_bantas
😁Thanks for the suggestions..it work for me with commnad.
