Move line
Move line
chan230984
Message 1 of 39
Move line
chan230984
Hi all. Please help me write lisp
I have a red line and a green line.
I want the green line Moved to the red line, With the green end of the line just attached to the red line
thanks
Accepted solutions (3)
Replies (38)
Message 21 of 39
sby0531
I have modified my code as follows:
(defun C:MvLines  (/		lst-RoadLine ena-GreenLine	       go-on1	    lst0-ena
		   lst1-ena	jud-proper   ena-LeftSlope	       ena-RoadTop  ena-RightSlope
		   pt01		pt02	     pt03	  pt04	       pt05	    pt06
		   width-road	dist0-hor    vect01	  vect02       sin01	    sin02
		   dist1-hor	vect03	     sin03	  jud-proper1  pt-int01	    pt-a
		   cons01	pt-int02     cons02	  pt-from      pt-from)
  (setq	m:err	*error*
	*error*	*merrmsg*)
  (Set-Cmdecho&Osnapcoord)
  (princ (strcat "\n Function : Move a green line and related culvert lines to proper"
		 " position between two red lines of road side slopes.\n"))
  (syms->T 'go-on0)
  (while go-on0
    (and
      ;;01
      (progn
	(syms->nil '(lst-RoadLine ena-GreenLine lst-CulvertLine))
	(syms->T 'go-on1)
	(while go-on1
	  (and
	    ;;A01
	    (setq lst0-ena (SsGet1
			     (list (strcat "Select the related lines(including 1 green"
					   " and 3 red): ")
				   "(Quantity of Selected lines)"
				   '((0 . "line"))
				   '(SymS->Nil '(go-on1 go-on0)))))
	    ;;A02
	    (progn
	      (setq jud-proper (>= (length lst0-ena) 4))
	      (if (not jud-proper)
		(princ-alert
		  "Quantity of Selected lines should not be less than 4!"))
	      jud-proper)
	    ;;A03
	    (progn
	      (setq lst1-ena   (all-if '(lambda	(ena0)
					  (= 3 (CL-ena ena0)))
				       lst0-ena)
		    jud-proper (= 1 (length lst1-ena)))
		(princ-alert "There should be 1(and only 1)GREEN line!"))
	      jud-proper)
	    ;;A04
	    (and
	      ;;B01
	      (progn
		(setq ena-GreenLine (car lst1-ena)
					       (= 1 (CL-ena ena0)))
					    lst0-ena)
		      jud-proper    (= 3 (length lst1-ena)))
		  (princ-alert "There should be 3(and only 3)RED lines!"))
		jud-proper)
	      ;;B02
	      (progn
		(setq jud-proper (P-Enas-3DLinkedLine lst1-ena))
		  (princ-alert "The 3 red lines should be linked!"))
		jud-proper))
	    ;;A05
	    (progn
	      (setq lst-RoadLine    lst1-ena
		    lst-CulvertLine (remove-items
				      (cons ena-GreenLine lst-RoadLine)
				      lst0-ena))
	      (syms->nil 'go-on1)))
	  (if lst0-ena
	    (UnHlight lst0-ena)))
	(and ena-GreenLine lst-RoadLine))
      ;;02
      (progn
	(syms->nil 'jud-proper1)
	(setq lst-RoadLine
	       (vl-sort	lst-RoadLine
			'(lambda (ena1 ena2 /)
			   (< (car (apply 'Vector+ (EndPoints0-Ena ena1)))
			      (car (apply 'Vector+ (EndPoints0-Ena ena2)))))))
	(mset '(ena-LeftSlope ena-RoadTop ena-RightSlope) lst-RoadLine)
	(mset '(pt01 pt02) (EndPoints-Ena ena-LeftSlope))
	(mset '(pt03 pt04) (EndPoints-Ena ena-RightSlope))
	(mset '(pt05 pt06) (EndPoints-Ena ena-GreenLine))
	(cond
	  ((progn
	     (setq width-road (distance pt02 pt03)
		   dist0-hor  (- (car pt03) (car pt02)))
	     (not (equal width-road dist0-hor 0.001)))
	   (princ-alert "The road top line should be level!"))
	  ((progn
	     (setq vect01 (VectorExpr->Vector (list pt01 pt02))
		   vect02 (VectorExpr->Vector (list pt03 pt04)))
	     (mset '(sin01 sin02)
		   (mapcar 'Sin-2dVector (list vect01 vect02)))
	     (or (<= sin01 0)
		 (>= sin02 0)
		 (and (equal 1 sin01 0.001)
		      (equal -1 sin02 0.001))))
	   (princ-alert
	     "The gradients of two side slopes should be proper!"))
	  ((progn
	     (setq dist1-hor (- (car pt06) (car pt05)))
	     (<= dist1-hor dist0-hor))
	   (princ-alert
	     (strcat "The horizontal length of the green line should exceed"
		     " that of the top red line!")))
	  ((progn
	     (setq vect03 (VectorExpr->Vector (list pt05 pt06))
		   sin03  (Sin-2dVector vect03))
	     (< (abs sin03) 1e-4))
	   (princ-alert "The culvert line should not be level!"))
	  (T
	   (syms->T 'jud-proper1)))
	jud-proper1)
      ;;03
      (setq pt-int01 (if (< sin03 0)
		       (Inters1	(list pt03 pt04)
				(list (setq pt-a (vector+ pt02 vect03))
				      (vector- pt-a vect01))
				nil)
		       (Inters1	(list pt01 pt02)
				(list (setq pt-a (vector- pt03 vect03))
				      (vector+ pt-a vect02))
				nil)))
      ;;04
      (progn
	(if (< (car pt-int01) (car pt03))
	  (setq	cons01	 (list ena-LeftSlope pt-int01 pt02)
		pt-int02 (vector+ pt-int01 vect03)
		cons02	 (list ena-RightSlope pt03 pt-int02)
		pt-from	 pt05)
	  (setq	cons01	 (list ena-RightSlope pt03 pt-int01)
		pt-int02 (vector- pt-int01 vect03)
		cons02	 (list ena-LeftSlope pt-int02 pt02)
		pt-from	 pt06))
	(cmd-move (cons ena-GreenLine lst-CulvertLine)
		  (list pt-from pt-int01))
	(foreach cons0	(list cons01 cons02)
	  (apply 'Put-EndPoints cons0))
	(princ "\n Done."))))
  (setq	*error*	m:err
	m:err	nil)
  (princ))
Message 22 of 39
chan230984
@sby0531
Hi friend
When I
Command: MVLINES
no function definition: SET-CMDECHO&OSNAPCOORD
Command:
Message 23 of 39
devitg
erased
Message 24 of 39
sby0531
@chan230984  已写:
@sby0531
Hi friend
When I
Command: MVLINES
Command:
Yes, it's normal. Because a lot of self-defined functions including Set-Cmdecho&Osnapcoord have been called directly and indirectly in the command function C:MvLines. I need to spend some time, perhaps one day , to pick out all the related self-defined functions and send them to you.  And only after loading all the  related self-defined functions, the command function C:MvLines can work.
The reason to develope so many commonly used self-defined functions is to simplify coding. I think it's the typical way for LISP coding.
Message 25 of 39
devitg
Message 26 of 39
john.uhden
Imagine if half way through the scribe's boss said, "Wait a second. I don't
like that font. Change it to a different style!" Or "I said landscape, not
portrait!"
John F. Uhden
Message 27 of 39
chan230984
@sby0531
Why does it work on your computer?
But can't work on my computer
Message 28 of 39
sby0531
@chan230984  已写:
@sby0531
Hi, I have added all the self-defined functions  called in C:MvLines to the attached LSP file, please download it and try. Good luck!
Message 29 of 39
chan230984
@sby0531
Thank you very much
Your help Make my work faster 😀
Message 30 of 39
ВeekeeCZ
Just a few lines which probably do the same as the multi-page solution code.
(vl-load-com)
(defun c:MoveGreenLine ( / s l e s1 s2 p m)
  (and (princ "\nSelect one green line and at least two slope lines of any color but green,")
       (setq s (ssget "_:L" '((0 . "LINE"))))
       (setq l (vl-remove-if 'listp (mapcar 'cadr (ssnamex s)))) 					; list of ents
       (setq l (mapcar '(lambda (x) (cons x (vl-sort (list (cdr (assoc 10 (entget x))) (cdr (assoc 11 (entget x)))) '(lambda (p r) (< (car p) (car r)))))) l))	; (en left-pt right-pt)
       (setq e (car (vl-remove-if-not '(lambda (x) (= 3 (cdr (assoc 62 (entget (car x)))))) l)))  	; green line
       (setq l (vl-remove e l))										; all but green line
       (setq l (vl-sort l '(lambda (p r) (> (abs (- (car (cdaddr p)) (cadadr p))) (abs (- (car (cdaddr r)) (cadadr r)))))))  ; sort reds by delta-y to get slopes
       (setq s1 (car l))									  	; first slope
       (setq s2 (cadr l))									  	; second slope
       (setq p (inters (setq m (polar (cadr s1) (angle (cadr e) (caddr e)) (distance (cadr e) (caddr e))))
		       (polar m (angle (cadr s1) (caddr s1)) (distance (cadr s1) (caddr s1)))
		       (cadr s2)
		       (caddr s2)))
       (vl-cmdf "_.move" (car e) "" "_non" (caddr e) "_non" p))
  (princ)
Message 31 of 39
chan230984
@ВeekeeCZ
thank you 😀
Message 32 of 39
chan230984
@ВeekeeCZ
Hi friend
Why does this Lisp work with some line?
Please check the files I attached.
Message 33 of 39
ВeekeeCZ
Ok, issue fixed. Also, accepted your color based distribution: now it moves all selected objects but red lines.
(vl-load-com)
       (setq l (mapcar '(lambda (x) (cons x (vl-sort (list (cdr (assoc 10 (entget x)))			; list of (en left-pt right-pt)
       (setq l (vl-remove-if-not '(lambda (x) (= 1 (cdr (assoc 62 (entget (car x)))))) l))		; all red lines
       (setq l (vl-sort l '(lambda (p r) (> (abs (- (car (cdaddr p)) (cadadr p)))			; sort reds by delta-y to get slopes
       (setq l (vl-sort (list (car l) (cadr l)) '(lambda (p r) (< (caadr p) (caadr r)))))    ; sort reds from left to right
		       (cadr s2)
		       (caddr s2)
		       nil))
       (vl-cmdf "_.move" (setq b (ssget "_P" '((-4 . "<>") (62 . 1)))) "" "_non" (caddr e) "_non" p))   ; move all selected but red lines
  (princ)
Message 34 of 39
chan230984
@ВeekeeCZ
wow...Perfect
thank you
Message 35 of 39
chan230984
@ВeekeeCZ
hi
"move all selected but red lines"
Can make it move the text, mtext and Dimension too?
thank you
Message 36 of 39
ВeekeeCZ
Post one sample to see... it's just about filters...
Message 37 of 39
chan230984
@ВeekeeCZ
Like this
attach
Message 38 of 39
ВeekeeCZ
Ok, here you go. Selection would be faster now.
(vl-load-com)
(defun c:MoveGreenLine ( / s l g s1 s2 p)
       (setq s (ssget "_:S"))										; _:S for quick single selection
       (setq l (vl-remove-if-not '(lambda (e) (and (vl-position (cdr (assoc 62 (entget e))) '(1 3))	; list of green & red lines
						   (= "LINE" (cdr (assoc 0 (entget e)))))) l))
       (setq g (car (vl-remove-if-not '(lambda (x) (= 3 (cdr (assoc 62 (entget (car x)))))) l)))  	; green line
       (setq l (vl-remove g l))										; all red lines
       (mapcar 'set '(s1 s2) l)										; set first and second slope line
       (setq p (inters (setq p (polar (cadr s1) (angle (cadr g) (caddr g)) (distance (cadr g) (caddr g))))
		       (polar p (angle (cadr s1) (caddr s1)) (distance (cadr s1) (caddr s1)))
		       (cadr s2)
		       (caddr s2)
		       nil))
       (vl-cmdf "_.move" (ssget "_P" '((-4 . "<>") (62 . 1))) "" "_non" (caddr g) "_non" p))   		; move all selected but red lines
  (princ)
Message 39 of 39
chan230984
@ВeekeeCZ
Thanks a lot for your help, That’s very perfect
