Move entity to sloping UCS along world UCS's Z-Axis
kpennell
kpennell
For now I only need this to work for a UCS where the X-Axis is sloping, as in the Y-Axis is plumb to world UCS.  I need a selected set of entities to move based on a point, projected to the current sloping UCS, but perfectly vertical.  Where would I start?
I would imagine, I would have to get the slope of the current UCS relative to the world UCS.  The only way I would know how to do that would be to create a line in the current sloping UCS, get in the world UCS, get the extended data of the line, delete it.  Now I got my slope.
I have the delta Z from picking my base point.  My Y point will be the same because it's only sloping in one direction, the x-axis is sloping.  I need to use trig to get my x value.
Does anyone think I'm not on the right path?
SEANT61
A drawing file, or an image, may help clarify the situation.  Though, it does certainly sounds like trig will be involved.
May your cursor always snap to the location intended.
Kent1Cooper
(setq
  conv (trans '(1 0 0) 1 0 T); conversion of 1,0,0 from current CS to WCS as displacement
  angrad (atan (/ (caddr conv) (car conv))); angle in radians
  angdeg (* (/ ang pi) 180); angle in degrees
); setq
[By the way, it's not the "world UCS" -- it's the "World CS" or WCS.  The U in UCS is, after all, for User, meaning something specified by the User different from the World Coordinate System.]
Kent Cooper, AIA
Kent1Cooper
@Kent1Cooper wrote:
(setq
); setq
Sorry [I was in a rush to get out the door] -- that should be:
  angdeg (* (/ angrad pi) 180); angle in degrees
[And in case it needs clarification, that gives the angle of the sloped X axis of the current UCS relative to the World X axis.]
Kent Cooper, AIA
