Move all circles to new center
Message 1 of 8
I need to move all circles on the page to a new point.
My current code is something like this:
(setq newCenter (getpoint "new center:"))
(setq circles (ssget "_X" '((0 . "CIRCLE")))) (setq n (sslength circles)) (setq x 0) (repeat n (setq name (ssname circles x)) (setq circle (entget name)) (setq center (cdr (assoc 10 circle)))
(setq circle (subst '(10 . newCenter) '(10 . center) circle))
(entmod circle)
(setq x (+ 1 x))
But, for some reason, it doesn't work. Need help!
Replies (7)
Message 2 of 8
ВeekeeCZ
This line has to be like this. '(variable) won't evaluate a variable
(setq circle (subst (cons 10 newCenter) (cons 10 center) circle))
Message 3 of 8
hak_vz
(setq circles (ssget "x" '((0 . "CIRCLE"))))
(setq x 0)
(repeat n
  (setq circle (subst (cons 10 newCenter) (assoc 10 circle) circle))
  (entmod circle)
  (setq x (+ 1 x))
Miljenko Hatlak
Message 4 of 8
CodeDing
@Anonymous ,
When using variables in list creation, you are not able to use the QUOTE ... ' ...
So, you must use the "list" and "cons" functions. Hope this helps!
(initget 1) (setq newCenter (getpoint "\nSelect new center: ")) (princ newCenter)
(if (setq circles (ssget "_X" (list '(0 . "CIRCLE") (cons 410 (getvar 'CTAB)))))
  (repeat (setq n (sslength circles))
    (setq name (ssname circles (setq n (1- n))))
    (entmod circle)
  );repeat
;else
  (prompt "\n...No circles found")
);if
Best,
~DD
Message 5 of 8
hak_vz
@CodeDing  @ВeekeeCZ  Here we have nice sequence how to update simple code.
Miljenko Hatlak
Message 6 of 8
ВeekeeCZ
Well, that was a nice coincidence... The sadder but expected thing is that the best answer is the least welcome.
Message 7 of 8
CodeDing
Lol, it's ok! Perhaps somebody in the future can find it useful still!
Message 8 of 8
Kent1Cooper
How 'bout something like this?  Instead of pulling apart entity data and replacing part of it, you can just assign the new Center more directly as a VLA property:
(vl-load-com); if necessary
(setq
  newCenter (getpoint "New Center for all Circles:")
); setq
  (vlax-put
    (vlax-ename->vla-object (ssname circles (setq n (1- n))))
    'Center newCenter
  ); vlax-put
); repeat
Kent Cooper, AIA
