Modifying workspace ribbon makes toolbars all hide.
I've struggled with this for 3 versions and need to get it worked out.
So I typically set up autocad with blank "custom.cuix" as the main menu, then load acad and others as partials.
I do that so I can modify theings like workspaces without modifying the acad OOTB menu.
So I get my toolbars and pulldowns shown how I want. I save that as a workspace and make sure its current in CUI.
I use CUI to add ribbon panels to that workspace, and hit Done, then OK.
The toolbars all dissapear.
If I reshow them, then close acad and reopen, they are there as well as the ribbon.
That is lousy though, as reshowing them is a pain.
Instead, I rename the current profile to junk, then reopen acad with arg path that recreates my previous profile.
Toolbars show fine, but no ribbon.
If I restore the workspace I made, the ribbon and toolbars go away (well, ribbon is blank...).
So that tells you the profile and workspace are somehow fighting with each other.
When I made the workspace, that is stored in my main menu (custom.cuix).
I should be able to restore that anytime and get my toolbars and ribbon.
Its simply broken.
I'm setting things up in a generic way too. Using custom.cuix has been recommended for years.
I can replicate this on all our workstations, its consistent. Anyone can if you start with a blank custom.cuix created in the CUI and set as meain, then load acad menu.
internal protected virtual unsafe Human() : mostlyHarmless
I'm just here for the Shelties
