modifying lisp to work for multiple circles
Message 1 of 14
Good Evening
i found this lisp on the internet that trim inside a circle
but it works by selecting one circle each time
i need to select all the circles in the drawing (almost 2200 circle) once and the lisp trimming them all
thanks in advance
(defun c:ctrim ( / circ_pts lst ang inc tmp seg pt ent
ctrim_err x f_pts svd_os svd_cmd svd_err)
(defun ctrim_err (s)
(if(/= s "Function cancelled")
(princ(strcat "\n\n" s)) )
(setvar "cmdecho" svd_cmd)
(setvar "osmode" svd_os)
(setq *error* svd_err)
(defun circ_pts (enm)
(setq lst (entget enm)
ang (* pi 2)
inc (/ ang 64)
tmp '()
seg 65
(repeat seg
(setq pt (polar(cdr(assoc 10 lst))ang
(-(cdr(assoc 40 lst))0.01))
ang (+ inc ang)
(setq tmp(cons pt tmp))
tmp
(setq ent (car(entsel "\nSelect circle: "))
svd_err *error*
*error* ctrim_err
svd_os (getvar "osmode")
svd_cmd (getvar "cmdecho")
(setvar "cmdecho" 0)
(setvar "osmode" 0)
(if(and ent
(=(cdr(assoc 0(entget ent)))"CIRCLE")
(progn
(setq f_pts(circ_pts ent))
(command "trim" ent "" "f") ;run twice in case the same
(foreach x f_pts(command x)) ;object intersects circle twice
(command "" "")
(command "" "")
(if(setq x(ssget "wp" f_pts))
(command "erase" x "")
(princ)
Replies (13)
Message 2 of 14
Kent1Cooper
The version of that >here< is made to do it with all Circles on a given Layer in the entire drawing.  Will that work for you?
Kent Cooper, AIA
Message 3 of 14
i noticed the code in the comments is that what you referring to?
if that so i cant find the command name that will be used in autocad
Message 4 of 14
Kent1Cooper
It's the CTRIM.lsp code attached to Message 1.  My link was to that Message specifically, not just to the Topic.
The command name is always what comes immediately after
(defun C:CommandNameHere
in this case, CTRIM just like the file name.
Kent Cooper, AIA
Message 5 of 14
marko_ribar
You can try code posted here :
https://www.cadtutor.net/forum/topic/37907-how-trim-many-line-inside-multi-circle-on-one-step/?do=fi...
HTH.
M.R.
Marko Ribar, d.i.a. (graduated engineer of architecture)
Message 6 of 14
i'm sorry if i didn't follow up with you but this code does not have defun c:ctrim
Message 7 of 14
i tried it but for some reason it didn't appear in command bar
Message 8 of 14
Kent1Cooper
Again, I wasn't linking to that thread for the code in Message 5 there, but to Message 1 there specifically, for the code in the file attached there.  See again the first sentence in Message 4 here.
But if you want to use the code in Message 5 there, shown in your image, the command name is farther down after some sub-routine definitions, but it's written for Polyline boundaries on a specific Layer, not for Circles that you asked about, as in what I was trying to direct you to.
Kent Cooper, AIA
Message 9 of 14
i downloaded it but it did nothing unfortunately
sorry for bothering you and thanks for helping
Message 10 of 14
Kent1Cooper
@Anonymous wrote:
i downloaded it but it did nothing unfortunately ....
Did you edit it at all?  As mentioned in my first Reply here, it's written for Circles on a specific Layer.  I doubt you have exactly that Layer name in your drawing, and you put all the desired Circles on it -- edit that for the name of the Layer of the Circles you're looking for.  If you don't want them selected by Layer, other edits can be made to have it ask for User selection, or other approaches.
If you've already changed that Layer name, tell us more about what "it did nothing" means.  Did it fail to load?  Did it load but the command name was not recognized?  Did it recognize the command name but nothing happened?  Did something happen, but not what you expected?  Were there any error messages?  Etc., etc., etc.
Kent Cooper, AIA
Message 11 of 14
all my circles are on a layer called (circle)
after i loaded lisp (Ctrim) it was loaded and recognized the name of the command but nothing happened
this is the drawing I'm working on
you may notice some of the circles are trimmed but those because I'm currently  trimming manually
Message 12 of 14
Kent1Cooper
That doesn't answer my first question.  Did you change the Layer name in the selection part of the routine?  It's written for Circles on a Layer called "MANHOLE."  Did you change this line:
(if (setq ss (ssget "_X" '((0 . "CIRCLE") (8 . "MANHOLE"))))
to this, to find your Circles on Layer "circle"?
(if (setq ss (ssget "_X" '((0 . "CIRCLE") (8 . "circle"))))
[not case-sensitive]
Kent Cooper, AIA
Message 13 of 14
IT WORKED !!
the name of the layer was the problem 😅😅
Really thanks a lot for being patient 🌹🌹
Message 14 of 14
Sea-Haven
Just a suggestion for me I tend to look at a more global answers saves the question in this topic "But I have another layer".
So I would ask user to select an object to get the layer name.
(setq lay (cdr (assoc 8 (entget (car (entsel "\nPick object for layer"))))))
(if (setq ss (ssget "_X" (list (cons 0 "CIRCLE") (cons 8 lay))))
