Modify texts in a dwg file
carlos_m_gil_p
Message 1 of 11
carlos_m_gil_p
Hello boys how are you.
You could help me with a routine to modify some texts.
I will attach a dwg so you can understand me.
Thank you.
Excuse my English, I only speak Spanish. 😞
AutoCAD 2026.1.1
Visual Studio Code 1.105.1
AutoCAD AutoLISP Extension 1.6.3
Windows 10 - 22H2 (64 bits)
Accepted solutions (3)
Replies (10)
Message 2 of 11
ВeekeeCZ
code edited.
(defun c:FixNumbers ( / dz ss i ed tx)
  (setq dz (getvar 'dimzin))
  (setvar 'dimzin 0)
  (if (setq ss (ssget '((0 . "*TEXT") (1 . "#*"))))
    (repeat (setq i (sslength ss))
      (setq ed (entget (ssname ss (setq i (1- i)))))
      (entmod (append (subst (cons 1 (rtos (atof (cdr (assoc 1 ed))) 2 3))
			     (assoc 1 ed)
			     ed)
		      '((41 . 0.) (71 . 5) (72 . 5) (75 . 0))))))
  (setvar 'dimzin dz)
  (princ)
Message 3 of 11
Kent1Cooper
In very simplest terms, try this:
(defun C:TEST ()
  (setq
    ss (ssget ":L" '((0 . "MTEXT")))
    dec (getint "\nNumber of decimal places: ")
  (repeat (setq n (sslength ss))
    (setq txt (vlax-ename->vla-object (ssname ss (setq n (1- n)))))
    (vla-put-TextString txt (rtos (atof (vla-get-TextString txt)) 2 dec))
    (vla-put-AttachmentPoint txt 5); middle-center justification
Set DIMZIN to some value to include trailing zeros, such as 3 [that could be built in if you want].  It depends on their being Mtext only, not plain Text.  And it depends on their all starting with numbers -- (atof) very conveniently translates only as far as numbers go, so there's no need to search for where the x is.
Kent Cooper, AIA
Message 4 of 11
Kent1Cooper
@ВeekeeCZ wrote:
'((41 . 0.) (71 . 5) (72 . 5) (75 . 0)))))) ....
That may be appropriate for Mtext, but not for Text [which is permitted in the selection, but shouldn't be if this is how it changes the justification].  The justification of plain Text is stored in a combination of the 72- and 73-code entries.
Kent Cooper, AIA
Message 5 of 11
carlos_m_gil_p
Hello how are you.
Thanks for the help, both solutions work very well.
One more question.
There is some way to know which is the largest number of decimals that the selected text has.
For example:
In the file that I had attached, of the original texts the one with the highest decimals was 3 decimals.
I ask this, because it would be the value that I would use to put the number of decimals to the new texts.
Thank you.
AutoCAD 2026.1.1
Message 6 of 11
dbhunia
Hi
For.....
@carlos_m_gil_p wrote:
One more question.
For example:
Try this........(For your particular type of drawings).....lightly tested
(defun C:CHN (/)
  (setq ss (ssget ":L" '((0 . "*TEXT"))))
  (setq dec 0)
  (repeat (setq n1 (sslength ss))
    (setq txt (vlax-ename->vla-object (ssname ss (setq n1 (1- n1)))))
    (setq NO (vla-get-TextString txt))
    (setq lst1 (parse NO "."))
    (setq DP (- (strlen (rtos (atoi (nth 1 lst1)) 2 1)) 2))
    (if (> DP dec) (setq dec DP))
(command "_.justifytext" ss "" "M")
(defun parse (str delim / lst pos)
(setq pos (vl-string-search delim str))
   (while (> pos 0)
	(setq lst (cons (substr str 1 pos) lst)
	      str (substr str (+ pos 2))
(if (> (strlen str) 0)(setq lst (cons str lst)))
(reverse lst)
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
Message 7 of 11
ВeekeeCZ
(defun c:RoundFirstNumber ( / dz ss i ed tx mx dc)
  (setvar 'dimzin 0)
  (if (and (setq ss (ssget '((0 . "MTEXT") (1 . "#*"))))
           (setq mx 0)
             (setq tx (cdr (assoc 1 (entget (ssname ss (setq i (1- i))))))
                   mx (max mx
                           (if (vl-string-search "." tx) 		; if the are decimals
                             (- (cond ((vl-string-search "x" tx))	; then substruct from x position
                                      ((strlen tx)))			;      or from last position if there is no x
                                (1+ (vl-string-search "." tx)))		;      the position of delimiter
                             0))))					; else, use 0 as no decimal
           (setq dc (cond ((getint (strcat "\nNumber of decimal places <" (itoa mx) ">: ")))
                          (mx)))
      (entmod (append (subst (cons 1 (rtos (atof (cdr (assoc 1 ed))) 2 dc))
			     (assoc 1 ed)
			     ed)
  (setvar 'dimzin dz)
  (princ)
Message 8 of 11
carlos_m_gil_p
Hi brother.
Thank you very much, it works very well.
AutoCAD 2026.1.1
Message 9 of 11
carlos_m_gil_p
Hello dbhunia.
Thanks for your help and help too.
I did the test but it did not work.
I do not know why.
Anyway later I review it calmly.
Thanks anyway.
AutoCAD 2026.1.1
Message 10 of 11
dbhunia
Hi
You are right in your drawing ......."DIMZIN"  is set to "8"...... I forgot to take care of that......
Now I take care of that...... Try this.......
(defun C:CHN (/)
  (setq DIM (getvar 'dimzin))
  (setvar 'dimzin 0)
  (setvar 'cmdecho 0)
  (setq dec 0)
(setvar 'dimzin DIM)
(setvar 'cmdecho 1)
(princ)
   (while (> pos 0)
(reverse lst)
Debashis Bhunia
Message 11 of 11
carlos_m_gil_p
Thanks for your solution.
It also works very well for me.
Greetings.
AutoCAD 2026.1.1
