Modify "Update Titleblock Attributes"
jtm2020hyo
Message 1 of 16
jtm2020hyo
I found this beautiful lisp: http://www.lee-mac.com/updatetitleblock.html
I need to add a column where I can export or import ObjectID and the Handle
PD: If possible I need one option to update automatically both: dwg and csv
Replies (15)
Message 2 of 16
Moshe-A
@jtm2020hyo  hi,
as far as i know ObjectIds and handles are read only and you can not set them to objects. AutoCAD generate them Automatically.
moshe
Message 3 of 16
jtm2020hyo
Its possible to modify such lisp to export ALL or SELECTED ITEMS with their IDs?
Message 4 of 16
Moshe-A
of course it's possible but the question is what would you do with it?
Message 5 of 16
jtm2020hyo
I might modify each each attribute dones my LibreOffice using the original UTB.lisp linked above.
Message 6 of 16
Moshe-A
tag names is the best way to modify attributes
Message 7 of 16
jtm2020hyo
I need to link cells with other since LibreOffice, such cells have a one number with was calculated with other formulas. I need to modify like 2000 tags.
Exporting IDs and updating with a CSV I can batch modify tags without errors.
Message 8 of 16
Moshe-A
what's  LibreOffice?
Message 9 of 16
jtm2020hyo
@Moshe-A wrote:
what's  LibreOffice?
an alternative to MS OFFICE.
Message 10 of 16
maratovich
ID changes every time a file is opened.
If you open the second time the ID file will be different.
Software development
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
Message 11 of 16
jtm2020hyo
does not exist someway to identify any unique object?
...maybe for example : rotation-position.
Message 12 of 16
maratovich
Unique object parameter - handle (it does not change when opening a file)
We do not know your ultimate goal.
We need to understand the whole process.
www.kdmsoft.net
Message 13 of 16
jtm2020hyo
I need identify each object of anyway. Then use a Lisp to export to CSV or Excel format (for example, export: dwg name,atribute tags , layout, uniqueID, block name), that dates of ALL or SELECTED objects. After that I need modify directly the CSV or Excel file and use the same lisp to import and update such dates.
...Or in resumen, I need export dates, modify in Excel and import dates.
Message 14 of 16
jtm2020hyo
...here I leave 2 attached files.
I need to export an excel format or .csv file, then update or combine dates of "SAMPLE.CSV" and "CUADRO DE CARGAS - MUSEO.xlsx", then import to the dwg.
Message 15 of 16
ronjonp
Have you tried the commands 'ATTIN' and 'ATTOUT' ?
Message 16 of 16
jtm2020hyo
thanks, sir.
This work as I need.
