Modify mtext paragraph in 300 drawings
townest
Message 1 of 8
townest
What would be a best practice for modifying an mtext paragraph (same pat phrase, same insert coordinates) that get updated every so often) in many drawings?  I have successfully used a lisp to just insert and redefine the text as a block, but not sure it's the best tactic.  Thank you.
Replies (7)
Message 2 of 8
CodeDing
@townest ,
Is it possible for you to XREF it? That way it could automatically be "redefined" every time somebody opens the drawing.
Best,
~DD
Message 3 of 8
townest
No, I need the object in the drawing.  Thank you.
Message 4 of 8
CodeDing
@townest ,
If you cannot use XREFs then I would say that you are currently using the best tactic. A block is the next best option.
Best,
~DD
Message 5 of 8
pbejse
To change the value without redefining any blocks or even opening the drawing.
I'll start with this..
Select you text file..
and there you have it...
HTH
Message 6 of 8
ronjonp
The best practice for something like this is an XREF as @CodeDing mentioned. Why can you not use an xref? You're making unnecessary work for yourself.
Message 7 of 8
SeeMSixty7
@ronjonp Just 300 times more work. GRIN!
Message 8 of 8
Sea-Haven
Each paragraph in mtext is a string of words as you know where you put it you could make a list of all the paragraph strings, go through them if = then substitute that entry in list and update the mtext you only need 1 character out of place and it will fail. Use the delimeter \\p
;   TextString = "EACH PARAGRAPH IN MTEXT IS A STRING\\POF WORDS AS YOU KNOW WHERE YOU PUT IT\\PYOU COULD MAKE A LIST OF ALL THE PARAGRAPH STRINGS,\\PGO THROUGH THEM IF = THEN SUBSTITUTE\\PTHAT ENTRY IN LIST AND UPDATE THE MTEXT\\PYOU ONLY NEED 1 CHARACTER OUT OF PLACE AND IT WILL FAIL. "
If its a couple of words what about find replace not Autocads but a lisp.
