Modify mleader arrowhead with vlisp
spykat
Message 1 of 11
spykat
On rare occasions I need to modify the arrowhead on a mleader. I've done it before but I cannot find my old code.
I can use:
(command "Mleader" pt5 pt6 "" answr)
(setq ent (ssname (ssget "L") 0))
(setq ldrobj (vlax-ename->vla-object ent))
(vla-put-arrowheadsize ldrobj 6.0)
and change the size, but I need to change arrowhead symbol from Closed filled to Dot blank.
Any ideas?
Replies (10)
Message 2 of 11
spykat
Never mind, I figured it out
Message 3 of 11
ronjonp
@spykat
You can modify that in the properties palette. Better yet make an mleaderstyle that has DotBlank as the arrowhead.
Message 4 of 11
ronjonp
Here's what I found works .. although I'd still manage this by styles and mleaderscale variable.
(command "_.Mleader" (getpoint) (getpoint) "")
(setq ent (entlast))
(vla-put-Arrowheadtype ldrobj 12)
Message 5 of 11
spykat
I just didn't want to add the step of changing it in the properties palette or to have to create a mleaderstyle just for 1 or 2 leaders in 1 out of 50 drawings.
I used (vla-put-ArrowheadBlock ldrobj "_DotBlank")
I was missing the underscore
Message 6 of 11
ronjonp
You might test that. I opened a blank drawing, inserted a leader and tried the method you're using and it threw an error (; error: Automation Error. Key not found ) because the block was not yet defined in the drawing. Documentation HERE.
I'd recommend:
(vla-put-Arrowheadtype ldrobj acArrowDotBlank)
Message 7 of 11
spykat
I tried that too and it still works. Dot blank is one of the default dimension blocks. I've never had to define it in a drawing in the past
Message 8 of 11
ronjonp
Weird. I can consistently replicate what I described above. Perhaps you're pulling from a template that already has it defined.
It always works with the method I proposed.
Message 9 of 11
spykat
I'm not using a template. I defined a text style and mleader style that was set to closed filled.
Message 10 of 11
ronjonp
Good for you. Glad you figured it out for yourself. 👍
Message 11 of 11
Sea-Haven
For anyone count from top to bottom, Blankdot is 12.
