Model Space Batchplot lisp
3arizona
Message 1 of 9
3arizona
i want to add a 1 or 2 extra columns.  when i change the columns to 5, lisp only prints 5 sheets regardless of the quantity i impute.
This how it works:
pick top corner of 8.5 x 11 sheet (sheet parameter are set)
it will prompt how may sheets you want to plot
plots 4 columns and however may sheets (rows) you want to plot after
this is the lisp.
(defun C:test ()
  (setq startpt (getpoint "\nSelect top-left corner of billpage grid: "))
  (setq bpcount (getint "\nSpecify number of billpages: "))
  (setq w_rows (fix (/ bpcount 4.0)))
  (setq bpheight 21.0)
  (setq bpwidth 16.0)
  (setq bpgap 2.5)
  (setq p_col (fix (rem bpcount 4)))
  (setq row 1)
  (setq x_0 (car startpt))
  (setq y_0 (cadr startpt))
  (while (<= row w_rows)
    (setq col 0)
    (while (<= col 3)
      (setq bl (list (+ x_0 (* col (+ bpwidth bpgap))) (- y_0 (+ (* row bpheight) (* (- row 1) bpgap)))))
      (setq tr (list (+ x_0 (+ (* (+ col 1) bpwidth) (* col bpgap))) (- y_0 (* (- row 1) (+ bpheight bpgap)))))
      (command "-plot")
      (command "y")
      (command "")
      (command "Bluebeam PDF.pc3")
      (command "Letter")
      (command "i")
      (command "p")
      (command "n")
      (command "w")
      (command bl)
      (command tr)
      (command "f")
      (command "")
      (command "y")
      (command "")
      (command "y")
      (command "")
      (command "n")
      (command "n")
      (command "y")
      (setq col (+ col 1))
    (setq row (+ row 1))
  (if (/= p_col 0)
    (progn
      (setq col 0)
      (while (<= col (- p_col 1))
	(setq bl (list (+ x_0 (* col (+ bpwidth bpgap))) (- y_0 (+ (* (+ 1 w_rows) bpheight) (* w_rows bpgap)))))
	(setq tr (list (+ x_0 (+ (* (+ col 1) bpwidth) (* col bpgap))) (- y_0 (* w_rows (+ bpheight bpgap)))))
	(command "-plot")
	(command "y")
	(command "")
	(command "")
	(command "")
	(command "i")
	(command "p")
	(command "n")
	(command "w")
	(command bl)
	(command tr)
	(command "f")
	(command "")
	(command "y")
	(command "")
	(command "y")
	(command "")
	(command "n")
	(command "n")
	(command "y")
  (princ)
Replies (8)
Message 2 of 9
maratovich
Do you have the same title blocks ?
Software development
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
Message 3 of 9
3arizona
yes, it's the same TB
Message 4 of 9
Ranjit_Singh
Try below and see if the right co-ordinates print. Then replace the print portion of code with plot as in Post #1.
(defun c:test  (/ bl bpcount bpgap bpheight bpwidth col coln p_col row startpt tr w_rows x_0 y_0)
       coln     6; Update column number here
       w_rows   (fix (/ bpcount coln))
       bpheight 21.0
       bpwidth  16.0
       bpgap    2.5
       p_col    (fix (rem bpcount coln))
       row      1
       x_0      (car startpt)
       y_0      (cadr startpt))
  (setq col 0)
  (princ "\n************")
  (princ (strcat "\nrow: " (itoa row) "\n"))
  (while (< col coln)
   (print bl)
   (print tr)
   (terpri)
   (setq col (+ col 1)))
  (setq row (+ row 1)))
 (cond ((/= p_col 0)
        (setq col 0)
         (print bl)
         (print tr)
         (terpri)
         (setq col (+ col 1)))))
 (princ))
Message 5 of 9
maratovich
I do not know Lisp well, but if there is not a solution here - there is another method of automatic printing from the model.
www.kdmsoft.net
Message 6 of 9
3arizona
When i paste the top portion of the my print properties it only gives me 1 sheet regardless of the quantity i ask for. If i change the bottom print potion as above it goes haywire, printing nonstop.   print parameters/coordinates are good
I don't know much about lisps. i thought it was a simple fix
see
(defun c:test1  (/ bl bpcount bpgap bpheight bpwidth col coln p_col row startpt tr w_rows x_0 y_0)
       bpheight 21.0
       bpwidth  16.0
       bpgap    2.5
       row      1
       x_0      (car startpt)
       y_0      (cadr startpt))
  (setq col 0)
  (while (< col coln)
      (command "-plot")
      (command "y")
      (command "")
      (command "Letter")
      (command "i")
      (command "p")
      (command "n")
      (command "w")
      (command bl)
      (command tr)
      (command "f")
      (command "")
      (command "y")
      (command "")
      (command "y")
      (command "")
      (command "n")
      (command "n")
      (command "y"))
   (terpri)
 (cond ((/= p_col 0)
        (setq col 0)
      (command "-plot")
      (command "y")
      (command "")
      (command "Letter")
      (command "i")
      (command "p")
      (command "n")
      (command "w")
      (command bl)
      (command tr)
      (command "f")
      (command "")
      (command "y")
      (command "")
      (command "y")
      (command "")
      (command "n")
      (command "n")
      (command "y"))
         (terpri)
 (princ))
lisp:
Message 7 of 9
maratovich
Attach a sample .dwg file
www.kdmsoft.net
Message 8 of 9
Ranjit_Singh
Here is how it works at my end. Be sure to follow the prompts at your command prompt for -plot and follow the sequence exactly in both the command functions.
       coln     6 ; Update column number here
       bpheight 21.0
       bpwidth  16.0
       bpgap    2.5
       row      1
       x_0      (car startpt)
       y_0      (cadr startpt))
  (setq col 0)
  (while (< col coln)
   (command "-plot" "y" "" "Adobe PDF.pc3" "Letter" "i" "p" "n" "w" bl tr "f" "" "y" "" "y" "" "n" "n" "y")
 (cond ((/= p_col 0)
        (setq col 0)
 (princ))
Message 9 of 9
3arizona
Ranjit.Singh.
Thanks, works perfect and friendlier.
