MOCORO - shortcut key?
MarkFitz
MarkFitz
A quick one today...
Is it possible to assign a shortcut key(s) to this command, as I'm starting to use it more, and hate mistyping it as a small country in northern Africa.  I went to my usual spot, AliasEdit, but the command isn't shown there, what am I doing wrong?
Mark
pendean
Community Legend
Community Legend
MOCORO is an Express tools, so LISP is an option if you want to do that, see this similar post from yesterday https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/command-alias-lisp-code/td-p/1191814...
fkellogg
Using the Add option in the aliasedit dialog worked for me.
Manually type in the MOROCO under the box to enter the shortcut.
johnyDFFXO
Even if the command is not in the offered list (but MOCORO is, as noted above), you can write it manually and ALIASEDIT will add it.
MarkFitz
Thanks guys!
marko_ribar
I still use mcr.lsp instead of MOCORO command... It was long time ago when I made it, but nevertheless it's very professionally written tool, so I never basically do anything without it...
Link : https://www.theswamp.org/index.php?topic=40547.msg481693#msg481693
HTH.
M.R.
Marko Ribar, d.i.a. (graduated engineer of architecture)
pendean
Community Legend
Community Legend
HTH.
M.R.
FYI it seems to work just fine in the now-lisp-enabled AutoCADLT2024 variant.
