Mleader Styles and Settings - Update with LISP
I have this lisp routine that creates a mleader style but it doesn't change any of the settings such as text height, arrow sizes, etc. At the end of the lisp routine under "(list...", I thought these settings would update the mleader settings but it doesn't. Can anyone help? I'm not an expert in coding by any means.
;;; Usage  : (CreateMLeaderStyle [NewStyleName] [ConfigList])
;;; Example: (CreateMLeaderStyle "Test"         '(("TextStyle" . "Standard")("TextHeight" . 2.5)))
;;; [NewStyleName] - String  -> Name of new MLeader Style
;;; [ConfigList]   - List    -> List with properties & values
(defun CreateMLeaderStyle (CMS_NewName CMS_Config / CMS_TextStyle CMS_MLeaderStyles CMS_NewMLeaderStyle CMS_Property CMS_ColorObject)
   (if
      (or
         (and
            (setq CMS_TextStyle (cdr (assoc "TextStyle" CMS_Config)))
            (tblsearch "STYLE" CMS_TextStyle)
         (not (cdr (assoc "TextStyle" CMS_Config)))
      (progn
         (setq CMS_MLeaderStyles (vla-item (vla-get-Dictionaries (vla-get-ActiveDocument (vlax-get-acad-object))) "ACAD_MLEADERSTYLE"))
         (if
            (vl-catch-all-error-p (vl-catch-all-apply 'vla-item (list CMS_MLeaderStyles CMS_NewName)))
            (progn
               (setq CMS_NewMLeaderStyle (vla-AddObject CMS_MLeaderStyles CMS_NewName "AcDbMLeaderStyle"))
               (if
                  (vla-put-TextStyle CMS_NewMLeaderStyle (getvar "TEXTSTYLE"))
               (foreach CMS_Item CMS_Config
                  (if
                     (and
                        (vl-consp CMS_Item)
                        (= (type (setq CMS_Property (car CMS_Item))) 'STR)
                        (not (listp (cdr CMS_Item)))
                        (vlax-property-available-p CMS_NewMLeaderStyle CMS_Property)
                     (cond
                           (wcmatch (strcase CMS_Property) "*COLOR*")
                           (setq CMS_ColorObject  (vlax-get-property CMS_NewMLeaderStyle CMS_Property))
                           (vla-put-ColorIndex CMS_ColorObject (cdr CMS_Item))
                           (vl-catch-all-apply 'vlax-put-property (list CMS_NewMLeaderStyle CMS_Property CMS_ColorObject))
                           T
                           (vl-catch-all-apply 'vlax-put-property (list CMS_NewMLeaderStyle CMS_Property (cdr CMS_Item)))
               (princ (strcat "\n ** Created " CMS_NewName " MLeader style"))
(setvar "CMLEADERSTYLE" "STANDARD")
             (princ "\n ** Error: MLeader style already exists")
      (princ "\n ** Error: textstyle does not exist")
   (princ)
(defun c:TEST ()
   (CreateMLeaderStyle "STANDARD"
      (list
         '("ArrowSize"               . 0.08)
         '("DoglegLength"            . 0.035)
         '("LandingGap"              . 0.08)
         '("LeaderLineColor"         . 7)
         (cons "ScaleFactor"         (getvar "DIMSCALE"))
         '("TextColor"               . 7)
         '("TextHeight"              . 0.08)
         '("TextLeftAttachmentType"  . 1)
         '("TextRightAttachmentType" . 1)
         '("TextStyle"               . "STANDARD")
   (princ)
dlanorh
You are trying to create a NEW style with a style name that already exists, hence it is failing. You should modify the style name in the test function to a name other than "Standard" then select all mleaders and change their style to the new mleader style, use the mleader style manager to alter the existing style  or find a lisp program that will alter an existing style rather than creating a new one.
I am not one of the robots you're looking for
dbhunia
For.....
Try this...... (It is not tested because I am unable to test it in AutoCAD 2007)
(defun CreateMLeaderStyle (CMS_NewName CMS_Config / CMS_TextStyle CMS_MLeaderStyles CMS_NewMLeaderStyle CMS_Property CMS_ColorObject) (if (or (and (setq CMS_TextStyle (cdr (assoc "TextStyle" CMS_Config))) (tblsearch "STYLE" CMS_TextStyle) ) (not (cdr (assoc "TextStyle" CMS_Config))) ) (progn (setq CMS_MLeaderStyles (vla-item (vla-get-Dictionaries (vla-get-ActiveDocument (vlax-get-acad-object))) "ACAD_MLEADERSTYLE")) (if (vl-catch-all-error-p (vl-catch-all-apply 'vla-item (list CMS_MLeaderStyles CMS_NewName))) (progn (setq CMS_NewMLeaderStyle (vla-AddObject CMS_MLeaderStyles CMS_NewName "AcDbMLeaderStyle")) (if (not (cdr (assoc "TextStyle" CMS_Config))) (vla-put-TextStyle CMS_NewMLeaderStyle (getvar "TEXTSTYLE")) ) (foreach CMS_Item CMS_Config (if (and (vl-consp CMS_Item) (= (type (setq CMS_Property (car CMS_Item))) 'STR) (not (listp (cdr CMS_Item))) (vlax-property-available-p CMS_NewMLeaderStyle CMS_Property) ) (cond ( (wcmatch (strcase CMS_Property) "*COLOR*") (setq CMS_ColorObject (vlax-get-property CMS_NewMLeaderStyle CMS_Property)) (vla-put-ColorIndex CMS_ColorObject (cdr CMS_Item)) (vl-catch-all-apply 'vlax-put-property (list CMS_NewMLeaderStyle CMS_Property CMS_ColorObject)) ) ( T (vl-catch-all-apply 'vlax-put-property (list CMS_NewMLeaderStyle CMS_Property (cdr CMS_Item))) ) ) ) ) (princ (strcat "\n ** Created " CMS_NewName " MLeader style")) (setvar "CMLEADERSTYLE" "STANDARD") ) ;(princ "\n ** Error: MLeader style already exists") (progn (initget "Y N") (setq CO (cond ((getkword "\nMLeader style already exists do you want to modify it [Yes/No] <No>: ")) ("N") ) ) (if (= CO "Y") (progn (setq CMS_NewMLeaderStyle (vla-getObject CMS_MLeaderStyles CMS_NewName)) (foreach CMS_Item CMS_Config (if (and (vl-consp CMS_Item) (= (type (setq CMS_Property (car CMS_Item))) 'STR) (not (listp (cdr CMS_Item))) (vlax-property-available-p CMS_NewMLeaderStyle CMS_Property) ) (cond ( (wcmatch (strcase CMS_Property) "*COLOR*") (setq CMS_ColorObject (vlax-get-property CMS_NewMLeaderStyle CMS_Property)) (vla-put-ColorIndex CMS_ColorObject (cdr CMS_Item)) (vl-catch-all-apply 'vlax-put-property (list CMS_NewMLeaderStyle CMS_Property CMS_ColorObject)) ) ( T (vl-catch-all-apply 'vlax-put-property (list CMS_NewMLeaderStyle CMS_Property (cdr CMS_Item))) ) ) ) ) (princ (strcat "\n ** Modified " CMS_NewName " MLeader style")) (setvar "CMLEADERSTYLE" "STANDARD") ) ) ) ) ) (princ "\n ** Error: textstyle does not exist") ) (princ) ) (defun c:TEST () (CreateMLeaderStyle "STANDARD" (list '("ArrowSize" . 0.08) '("DoglegLength" . 0.035) '("LandingGap" . 0.08) '("LeaderLineColor" . 7) (cons "ScaleFactor" (getvar "DIMSCALE")) '("TextColor" . 7) '("TextHeight" . 0.08) '("TextLeftAttachmentType" . 1) '("TextRightAttachmentType" . 1) '("TextStyle" . "STANDARD") ) ) (princ) )
For 2nd part.......I think this would be better for you.....
(defun c:TEST ( / MLS)
(setq MLS (getstring T "\nEnter MLeader Style Name to Create a New / Modify an Existing one: "))
   (CreateMLeaderStyle MLS
      (list
         '("LeaderLineColor"         . 3)
         '("TextColor"               . 3)
         '("TextHeight"              . 0.15)
         '("TextStyle"               . "STyle1")
(princ)
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
