Mleader Coordinates LISP
Message 1 of 10
Hi guyz,
I want to make LISP using Mleader to show Easting and Northing. However, my LISP outcome was shown Easting only. Anyone can help me? my attempt is in below. Thanks.
I want like this:
E=0.000
N=0.000
Ardz
Replies (9)
Message 2 of 10
imadHabash
Hi and Welcome to AutoDesk Forum,
>> I want to make LISP using Mleader to show Easting and Northing <<
we call this Text Field value NOT a lisp.i suggest to follow this VIDEO to learn how to make it.
Good Luck..
Imad Habash
Message 3 of 10
ВeekeeCZ
Try it like this...
(defun C:XY (/ PNT1 P1X P1Y STDY DY PTXT )
  (setq PNT1 (getpoint "\nPick coordinate point: "))
  (setq P1X (car pnt1)) ;x coord
  (setq P1Y (cadr pnt1)) ;y coord
  (setq STDX (rtos P1X 2 3))
  (setq STDY (rtos P1Y 2 3))
  (setq COORD (strcat "E=" STDX "\nN=" STDY))
  (setq PTXT (getpoint "\nPick text location: "))
  (command "mleader" PNT1 PTXT COORD)
  (princ)) ; end
And little shorter version. The leader shows dynamically while the creation. It works under UCS as well.
(defun C:XY (/ pnt coord)
  (if (and (setq pnt (getpoint "\nPick coordinate point: "))
           (setq pnt (trans pnt 1 0))
           (setq coord (strcat "E="   (rtos (car pnt) 2 3)
                               "\nN=" (rtos (cadr pnt) 2 3)))
    (command "_.mleader" "_none" pnt PAUSE coord))
  (princ))
Message 4 of 10
TourajM
Hi, will you please add a Z value to the lisp?
E=
N=
H=
Message 5 of 10
Sea-Haven
If you study the code the answer was in front of you.
(defun C:XYZ (/ pnt coord)
  (while (setq pnt (getpoint "\nPick coordinate point Enter to exit : "))
  (progn
		     	          "\nZ=" (rtos (caddr pnt) 2 3))
  (princ)
Look at the car, cadr & caddr functions.
Message 6 of 10
TourajM
I figured it out that much, but I got the
Pick coordinate point Enter to exit : ; error: too few arguments
Message 7 of 10
Sea-Haven
Works for me, check lispsys = 1. Not sure otherwise. You could remove the progn not really needed.
Message 8 of 10
TourajM
Doesn't work. Is only added Z to this because working fine.
(princ)) ; end
Message 9 of 10
Sea-Haven
Version 2, added line from pnt.
  (progn
       (command "_.mleader" "_none" pnt (getpoint pnt "\npick point for text ") coord)
  (princ)
Message 10 of 10
TourajM
Yes, This is working. Thanks.
