Mirror: Rotation and X Scale
renanemeyer
Message 1 of 24
renanemeyer
Hello everybody.
I come to clarify a doubt, if anyone has any better ideas I also accept suggestions.
I often use the mirror in autocad, but in the mirror upwards it assigns a rotation 180 or when the mirror is on the side it assigns -1 in Scale X.
See the example photo
I thought about creating a lisp that would take everything from this layer and adjust these mirrors to rotation 0 and X Scale = 1, but I come to ask if anyone already has something I can base myself on or could help me stop this repetitive work .
Thanks in advance
Replies (23)
Message 21 of 24
ВeekeeCZ
So you will select possibly multiple block sets (with horizontal and leader lines).
Then you want to specify what
- point and keyword (H/V)?,
- or just keyword and mirror it around the edge of the bounding box?
- or two points to spefify axis? (one, and second with ortho?)
Message 22 of 24
ВeekeeCZ
... or simply like this.
(defun c:MirrSetH ( / s p r i d d10 d11 m b)
  (if (and (setq s (ssget "_:L"))
	   (setq p (getpoint "\nSpecify point: "))
	   (setq r (ssget "_P" '((0 . "~INSERT"))))
	   (vl-cmdf "_.mirror" r "" "_non" p "_non" "@0,1" "_n")
    (repeat (setq i (sslength s))
      (and (setq d (entget (ssname s (setq i (1- i)))))
	   (= "LINE" (cdr (assoc 0 d)))
	   (setq d10 (cdr (assoc 10 d)))
	   (setq d11 (cdr (assoc 11 d)))
	   (equal (cadr d10) (cadr d11) 1e-6)
	   (setq m (trans (mapcar '/ (mapcar '+ d10 d11) '(2 2)) 0 1))
	   (setq b (ssget "_CP" (list (polar d10 (/ pi 2) 0.05) (polar d11 (/ pi 2) 0.05) (polar d11 (/ pi 2) -0.05) (polar d10 (/ pi 2) -0.05)) '((0 . "INSERT"))))
	   (command "_.copy" b "" "_d" "_non" (list (* 2 (- (car p) (car m))) 0.)))))
  (princ)
(defun c:MirrSetV ( / s p r i d d10 d11 m b)
	   (vl-cmdf "_.mirror" r "" "_non" p "_non" "@1,0" "_n")
	   (command "_.copy" b "" "_d" "_non" (list 0. (* 2 (- (cadr p) (cadr m))))))))
  (princ)
Message 23 of 24
renanemeyer
 Dear @ВeekeeCZ  congratulations!
You solved a code that I've been trying to solve for days, it was very well thought out and the idea of ​​vertical/horizontal too
Excellent logic, thank you very much
Message 24 of 24
ВeekeeCZ
Glad to help, @renanemeyer
Yeah, I know what youre talking about. Sometimes the fresh eyes do wonders.
