Mirror object automatically
jonathan.craig
jonathan.craig
I am looking for a way to get entities too be automatically mirrored from a reference axis And updating everytime i put a new object.
im a working on a structure on a deck of a boat. I want to be able too work only on one side of the boat as the other side of the reference line in red mirrors automaticaly everything i do over it.
Hope this is clear.
thanks !
Ps: here the link of what i want to achieve (not in 3d tho)
https://www.youtube.com/watch?v=3LwQO_tWTAQ
Kent1Cooper
Define one half of it as a Block, Mirror that across the center-line axis, and do your working-on-it within REFEDIT or BEDIT.  When you get out of that and Save the changes, the other side will update.
Kent Cooper, AIA
Shneuph
Kent's advice is very sound.  I much prefer refedit to bedit.  I only use bedit if I'm going to use dynamic properties in a block.
I use blocks a ton and refedit alot so I wrote some simple lisp to help speed the editing up.
(Defun C:TLC-Reference_Edit ()
(setvar "cmdecho" 1)
(command "-refedit" pause "O" "A" "Y")
(setvar "cmdecho" 0)
(progn)
);defun
and
(Defun C:TLC-Reference_Save ( / tlv-refname)
(if (/= (getvar "refeditname") "")
(progn
(setq tlv-refname (getvar "refeditname"))
(command "refclose" "s")
(command "attsync" "n" tlv-refname)
);progn
(princ "Not in Ref Edit Mode. Exiting")
);if
(princ)
);defun
You can add to your .pgp file like I did if you like:
RED, *TLC-Reference_Edit
RS, *TLC-Reference_Save
---sig---------------------------------------
'(83 104 110 101 117 112 104 64 71 109 97 105 108 46 99 111 109)
john.uhden
What's wrong with the Extend command, especially with Fence?  Or are the port->starboard lines supposed to be separate, port and starboard?
John F. Uhden
Kent1Cooper
Surely nothing's wrong with Extend, but widen your horizons -- there are so  many other kinds of "work" they might want to do on it [add linework running in other directions than perpendicular to the mid-line, openings, bolts, re-shape the perimeter, hatch areas, etc., etc.].
Kent Cooper, AIA
john.uhden
... winches, cleats, vents, stanchions, barber hauls, lee boards, side stays, back stays, Harken blocks, life boats, hoists, railings, gun mounts, swimming pools and slides, bocci courts, shuffle board courts, tiki bars, etc., etc., etc.
John F. Uhden
