I tried another way to optimize the occupied area.
(defun clockwise ( p1 p2 p3 )
(* (- (car p2) (car p1)) (- (cadr p3) (cadr p1)))
(* (- (cadr p2) (cadr p1)) (- (car p3) (car p1)))
(defun c:imbric ( / js n ent dxf_ent lst_pt tmp_lst lst_d where lst_dir lst_pt_all minpt1 maxpt1 minpt2 maxpt2 minpt maxpt good result)
(setq js (ssget '((0 . "LWPOLYLINE") (-4 . "<AND") (-4 . "&") (70 . 1) (-4 . ">") (90 . 2) (-4 . "AND>") (-4 . "<NOT") (-4 . "<>") (42 . 0.0) (-4 . "NOT>"))) lst_pt_all nil good nil)
(cond
((and js (< (setq n (sslength js)) 3))
(setvar "CMDECHO" 0)
(repeat n
(setq
ent (ssname js (setq n (1- n)))
dxf_ent (entget ent)
lst_pt (mapcar '(lambda (x) (trans x ent 0)) (mapcar 'cdr (vl-remove-if '(lambda (x) (/= (car x) 10)) dxf_ent)))
tmp_lst nil
(if (not (clockwise (car lst_pt) (cadr lst_pt) (caddr lst_pt)))
(setq lst_pt (reverse lst_pt))
(if (zerop n) (setq lst_pt (reverse lst_pt)))
(setq
lst_d (mapcar 'distance lst_pt (cons (last lst_pt) lst_pt))
where (- (length lst_pt) (length (member (apply 'max lst_d) lst_d)))
(repeat (length lst_pt)
(setq
tmp_lst (cons (nth where lst_pt) tmp_lst)
where (if (> (1+ where) (1- (length lst_pt))) 0 (1+ where))
(setq
lst_pt tmp_lst
lst_dir (mapcar 'angle lst_pt (append (cdr lst_pt) (list (car lst_pt))))
lst_pt_all (cons (mapcar 'cons lst_pt lst_dir) lst_pt_all)
(foreach el (car lst_pt_all)
(foreach p (cadr lst_pt_all)
(command "_.move" (ssname js 1) "" "_none" (car p) "_none" (car el))
(command "_.rotate" (ssname js 1) ""
"_none" (car el)
"_reference" (car el)
(polar (car el) (cdr p) (distance (car p) (car el)))
(polar (car el) (cdr el) (distance (car p) (car el)))
(cond
(length
(vlax-invoke
(vlax-ename->vla-object (ssname js 1))
'IntersectWith
(vlax-ename->vla-object (ssname js 0))
acExtendNone
7
(vla-GetBoundingBox (vlax-ename->vla-object (ssname js 0)) 'mnpt 'mxpt)
(setq
minpt1 (trans (safearray-value mnpt) 0 1)
maxpt1 (trans (safearray-value mxpt) 0 1)
(vla-GetBoundingBox (vlax-ename->vla-object (ssname js 1)) 'mnpt 'mxpt)
(setq
minpt2 (trans (safearray-value mnpt) 0 1)
maxpt2 (trans (safearray-value mxpt) 0 1)
minpt
(list
(apply 'min (mapcar 'car (list minpt1 minpt2)))
(apply 'min (mapcar 'cadr (list minpt1 minpt2)))
maxpt
(list
(apply 'max (mapcar 'car (list maxpt1 maxpt2)))
(apply 'max (mapcar 'cadr (list maxpt1 maxpt2)))
(setq good
(cons
(cons
(* (- (car maxpt) (car minpt)) (- (cadr maxpt) (cadr minpt)))
(cons
(list minpt maxpt)
(cons el p)
good
; (getkword "\nNext position") ; uncomment for see evolution
(command "_.u" "_.u")
(cond
(good
(setq result (cdr (assoc (apply 'min (mapcar 'car good)) good)))
(command "_.undo" "_begin")
(command "_.pline"
"_none" (caar result)
"_none" (list (caadar result) (cadaar result))
"_none" (cadar result)
"_none" (list (caaar result) (cadr (cadar result)))
"_close"
(setq result (cdr result))
(command "_.move" (ssname js 1) "" "_none" (cadr result) "_none" (caar result))
"_reference" (caar result)
(polar (caar result) (cddr result) (distance (caar result) (cadr result)))
(polar (caar result) (cdar result) (distance (caar result) (cadr result)))
(command "_.undo" "_end")
(setvar "CMDECHO" 1)
(T (princ "\nMust be select only 2 polylines!"))
(prin1)
