mid and end points of lines and arcs
dario_jukica
Message 1 of 30
dario_jukica
Hi.
I have a drawing with multiple lines and arcs.
I need to place a point od every line end and every arc end and every arc mid.
Overkill at the end to delete multiple.
Please help.
Thank you.
Kind regards,
Dario
Replies (29)
Message 2 of 30
ВeekeeCZ
Try this.
(vl-load-com)
(defun c:linarcpoints ( / s e i a b c p l)
  (if (setq s (ssget '((0 . "ARC,LINE"))))
    (repeat (setq i (sslength s))
      (setq e (ssname s (setq i (1- i)))
	    a (vlax-curve-getstartpoint e)
	    b (vlax-curve-getendpoint e)
	    c (if (= "ARC" (cdr (assoc 0 (entget e))))
		(vlax-curve-getpointatdist e (/ (vlax-curve-getdistatparam e (vlax-curve-getendparam e)) 2))))
      (foreach p (list a b c)
	(if (and p (not (vl-remove-if-not '(lambda (x) (equal p x 1e-5)) l)))
	  (setq l (cons p l))))))
  (foreach p l (entmake (list '(0 . "POINT") (cons 10 p))))
  (princ)
Message 3 of 30
komondormrex
another take
(vl-load-com)
(defun c:mark_end_mid (/ line_arc_sset)
  (setq line_arc_sset (ssget '((0 . "line,arc"))))
  (foreach ename (vl-remove-if 'listp (mapcar 'cadr (ssnamex line_arc_sset)))
	(foreach point (list (vlax-get (vlax-ename->vla-object ename) 'startpoint)
			     (vlax-get (vlax-ename->vla-object ename) 'endpoint)
			     (if (vlax-property-available-p (vlax-ename->vla-object ename) 'center)
				     (vlax-curve-getpointatparam (vlax-ename->vla-object ename) (* 0.5 (+ (vlax-curve-getendparam (vlax-ename->vla-object ename))
													  (vlax-curve-getstartparam (vlax-ename->vla-object ename))
			       	     nil
			  (if point (ssadd (vlax-vla-object->ename (vla-addpoint (vla-get-block (vla-get-activelayout (vla-get-activedocument (vlax-get-acad-object))))
				                         			 (vlax-3d-point point)
					   line_arc_sset
  (command "_-overkill" line_arc_sset "" "_d")
  (princ)
Message 4 of 30
_gile
This should work for the mid point of most of the curve entities (Line, Arc, Circle, Ellipse, Polyline, Spline)
(defun vlax-curve-getMidPoint (curve / endParam)
  (if (setq endParam (vlax-curve-getEndParam curve))
    (vlax-curve-getPointAtDist
      curve
      (/ (vlax-curve-getDistAtParam curve endParam) 2.)
Testing command:
(defun c:test (/ ss i c)
  (if (setq ss (ssget '((0 . "ARC,CIRCLE,ELLIPSE,LINE,LWPOLYLINE,SPLINE"))))
    (repeat (setq i (sslength ss))
      (setq c (ssname ss (setq i (1- i))))
      (foreach p (list (vlax-curve-getMidPoint c)
		       (vlax-curve-getEndPoint c)
	(entmake
	  (list
	    (cons 0 "POINT")
	    (cons 10 p)
  (princ)
Gilles Chanteau
GileCAD
GitHub
Message 5 of 30
Kent1Cooper
(defun C:TEST (/ ss n ent)
  (if (setq ss (ssget '((0 . "LINE,ARC"))))
    (repeat (setq n (sslength ss))
      (setq ent (ssname ss (setq n (1- n))))
      (command
        "_.point" "_non" (vlax-curve-getstartpoint ent)
        "_.point" "_non" (vlax-curve-getendpoint ent)
      (if (member '(0 . "ARC") (entget ent))
        (command "_.point" "non"
          (vlax-curve-getpointatdist ent (/ (vlax-curve-getdistatparam ent (vlax-curve-getendparam ent)) 2))
  (prin1)
Kent Cooper, AIA
Message 6 of 30
Kent1Cooper
[For both @_gile and @komondormrex :  They didn't want Points at the midpoints of Lines, only Arcs.  But they did want them at the start points of both, which it looks like @_gile's doesn't do.]
[Also, a small thing, but....  Your 2. can be just 2 -- the potential division "problem" is only when both numbers are integers, but what you're dividing there will always be a real number, so the 2 doesn't need to be.]
Kent Cooper, AIA
Message 7 of 30
komondormrex
you're **** right)
Message 8 of 30
_gile
I did not try to give the OP an out of the box solution wich exactly reply to its request. I always tend to provide more genric function helpers for the OP to solve the problem by itself.
The testing command I posted is just to show how the vlax-curve-getMidPoint custom function and the vlax-curve-getEndPoint native one can be used to solve the OP request and also how it works with most of the curve entities.
I think it is a good practice to always use real numbers for operations that must return a real number. It makes the intentions of the code immediately explicit to the reader and it avoids a conversion to the compiler (this is also a habit with F# language which does not tolerate any implicit conversion).
Gilles Chanteau
GileCAD
GitHub
Message 9 of 30
komondormrex
imho they are succesive lines and arcs, so overkill is needed to kill coincident points
Message 10 of 30
dario_jukica
This works great.
Can you please add an overkill at the end...I'm getting some random duplicate points.
Thank you.
Cheers
Message 11 of 30
ВeekeeCZ
Ok, try the updated code.
Message 12 of 30
dario_jukica
Works great, thank you very much.
Message 13 of 30
Sea-Haven
I may be wrong looking at code above but why not, is there a point already there, check so no need for the "Overkill" what about 2 lines joining do put end  & start = 4 points when should only be 3.
Message 14 of 30
dario_jukica
Is it too much to ask for an expansion of the code...please advise if I have to open a new topic.
The problem you have solved here is the first part of the task.
After that, I have to name them starting with a specific number. Standard style, height 1.25. Names must be placed in a closest possible position so that they don't overlap with each other or any of the lines.
Once numbered I have to gather all the coordinates (2 decimal points) end export them to an excel table (name, X, Y, Z)
Thank you.
Message 15 of 30
ВeekeeCZ
Not at all. But you know, the code is so simple that it's pretty self-explanatory.
So do you understand at least something and say have issues with one or two lines?
Message 16 of 30
dario_jukica
I have no clue about coding, unfortunately, took a look at it but it makes no sense to me.
Message 17 of 30
ВeekeeCZ
Ooh... my bad, now I see it. You wanted an expansion, not an explanation.
Well, probably better to start over. Post drawing with examples of the desired outcomes - Both, dwg and txt.
Message 18 of 30
dario_jukica
Attached please find an example of the finished files.
Message 19 of 30
ВeekeeCZ
That's a quite common task with plenty od solutions already written. All you need is to search.
Message 20 of 30
dario_jukica
You are correct, there are a few solutions out there but non of the ones I found do what I need and since I don't know how to code I don't know how to adapt them to my needs.
Tried using ChatGPT to help me out but we weren't able to figure it out.
Will keep searching then.
Thank you.
