Merging Files 10dwg into 1dwg
I need a Solution/Script for Merging 10+Dwg/dxf into Single DWG/DXF
Solution will be Like will give the Location of folder there is 10+ Dwg/Dxf then the Script should combine it and give it as Single Dwg/Dxf
Something like this
(command "_insert" "C:\\1.dwg" "0,0" "1" "1" "0")
maratovich
Use this: Revers
Software development
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
