Merge layer and keep hidden object in hidden
fkp7057
fkp7057
Hello Lisp Programmer,
I need LSP program for layer merging.
for example, I have one block and its having no. of object in block in different different layer.
i want merge to all visible layers to in one layer and all hidden,frozen layers to one layer,  is it be possible using LSP program. if any one having this type of LSP please share it .
Thanks in advance.
>>Sorry for any grammatical error, I'm using google to translate.<<
Let me see if I get it.
You have several layers in your drawing, some visible, some not.
Visible, you want to select objects and place them on a layer
and not visible in another?
Júnior Nogueira.
Por favor,  Aceitar como Solução se meu post te ajudar.
Please Accept as Solution if my post helps you.
fkp7057
exactly !!  i want to put all visible object in layer-1 and all invisible, frozen, object in layer-2
