measure levels
measure levels
measure levels
;Lisp-Marking Levels.......
(defun c:LVL()
(setq p1(getreal"\Enter Datum Level:")
ptx(rtos p1 2 3 )
po(getpoint"\Pick Datum Point:")
idy(cadr po) )
(if(> p1 0)(COMMAND "text" "BL" po "200" "0" (strcat "+" ptx" m") "")
(COMMAND "text" "BL" po "200" "0" (strcat ptx" m") ""))
(while p1
(setq NT(getpoint "\n Pick Next Level:"))
(if NT
(progn
(setq y1 (cadr NT)
d(/(- y1 idy)1000 )
d1(+ d p1))
(setq txt (rtos d1 2 3) )))
(if(> d1 0)(COMMAND "text" "BL" nt "200" "0" (strcat "+" txt" m") "")
(COMMAND "text" "BL" nt "200" "0" (strcat txt" m") "")))
(Princ"Program written by 'Denson Davis'"))
BeKirra
Do you ask for help or something else?
Please specify your question with more details. Thank you.
If you are asking for help, please take note of "text" command format:
(command "text" "justify" "BL" InsertionPoint "TextHeightValue" "RotationAngleValue" "TextContent")
Without looking to your code details, you may remove the "" (in red) from your text command:
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
