Match block visibility from source to destination.
smallƑish
smallƑish
Is that possible to write a lisp to match Visibility of a Dynamic block to another one. Same like match properties in default autocad.
ВeekeeCZ
(vl-load-com)
(defun c:MatchVisibility ( / LM:getvisibilityparametername e p v s i)
  ;; http://www.lee-mac.com/dynamicblockfunctions.html#getvisibilityparametername
  ;; Get Visibility Parameter Name  -  Lee Mac
  ;; Returns the name of the Visibility Parameter of a Dynamic Block (if present)
  ;; blk - [vla] VLA Dynamic Block Reference object
  ;; Returns: [str] Name of Visibility Parameter, else nil
  (defun LM:getvisibilityparametername ( blk / vis )
    (if (and (vlax-property-available-p blk 'effectivename)
	     (setq blk (vla-item (vla-get-blocks (vla-get-document blk))
				 (vla-get-effectivename blk)))
	     (= :vlax-true (vla-get-isdynamicblock blk))
	     (= :vlax-true (vla-get-hasextensiondictionary blk))
	     (setq vis (vl-some '(lambda ( pair ) (if (and (= 360 (car pair))
							   (= "BLOCKVISIBILITYPARAMETER" (cdr (assoc 0 (entget (cdr pair))))))
						    (cdr pair)))
				(dictsearch (vlax-vla-object->ename (vla-getextensiondictionary blk)) "ACAD_ENHANCEDBLOCK"))))
      (cdr (assoc 301 (entget vis))))
  (if (and (setq e (car (entsel "\nSelect source block: ")))
	   (or (= "INSERT" (cdr (assoc 0 (entget e))))
	       (prompt "\nError: Selected object is not a block!"))
	   (or (setq p (LM:getvisibilityparametername (vlax-ename->vla-object e)))
	       (prompt "\nError: Selected block has no visibility parameter!"))
	   (setq v (getpropertyvalue e (strcat "AcDbDynBlockProperty" p)))
	   (princ "\nSelect destination blocks...")
    (while (setq s (ssget "_:S" '((0 . "INSERT"))))
      (repeat (setq i (sslength s))
	(if (setq p (LM:getvisibilityparametername (vlax-ename->vla-object (setq e (ssname s (setq i (1- i)))))))
	  (vl-catch-all-apply 'setpropertyvalue (list e (strcat "AcDbDynBlockProperty" p) v))))))
  (princ)
smallƑish
Thank you So much it's perfect.
bfalconr
Hi, sorry to bother, shoult I type MatchVisibility in autocad to get it work?
Please let me know,
Thank you
Bruno Falcon
Sea-Haven
You can add (c:MatchVisibility) as last line, then when you load it the first time it wil run, if you want to run again yes type "MatchVisibility" you could make the function name shorter or add a new defun with an abbreviation. NOTE can not use "MV" that is already used by CAD.
You could add this at end of code .
(defun c:Mvis ( / )
(command "MatchVisibility")
You should add this at the start of code, as recognition of who provided code.
; Match visibilty between dynamic blocks
; By BeekeeCZ March 2025
