manipulation string
manipulation string
alexandre_benekowski
Message 1 of 8
manipulation string
Hi people,
I have a string that i´d like to count in a different way. I know (and use) "strlen" but it is not what i want. So, i´d like to count numbers of characters before "+" and after "+":
ex:
1+25
answer
1 and 2
100+25.00
answer
3 and 5
Someone could help me?
Replies (7)
Message 2 of 8
ronjonp
Quick example:
(defun _foo (string del / i)
  (if (setq i (vl-string-search del string))
    (list (setq i (strlen (substr string 1 i))) (- (strlen string) (1+ i)))
(_foo "100+25.00" "+")
;; (3 5)
Message 3 of 8
doaiena
I've made a small edit to @Lee_Mac's String to List function. It will work with multiple entries.
;Lee Mac's LM:str->lst routine /with a small edit/
;http://lee-mac.com/stringtolist.html
(defun LM:str->lst ( str del / len lst pos ) (setq len (1+ (strlen del))) (while (setq pos (vl-string-search del str)) (setq lst (cons (strlen (substr str 1 pos)) lst) str (substr str (+ pos len)) ) ) (reverse (cons (strlen str) lst)) ) ;;;output: ;(LM:STR->LST "100+25.00+15+22.5+109" "+") ;(3 5 2 4 3)
Message 4 of 8
ronjonp
;;;output:
;(3 5 2 4 3)
FWIW .. no need to change Lee's code. To get the result you have shown, call it like this:
(mapcar 'strlen (lm:str->lst "100+25.00+15+22.5+109" "+"))
Message 5 of 8
doaiena
That works too. It just makes the statement a bit longer. Depends on @alexandre_benekowski's needs.
Message 6 of 8
ronjonp
Sure .. I'd think the outcome would be something more like this from the description.
(setq l (mapcar 'strlen (lm:str->lst "100+25.00+15+22.5+109" "+")))
(mapcar '(lambda (r j) (list r j)) l (cdr l))
;; '((3 5) (5 2) (2 4) (4 3))
Message 7 of 8
Kent1Cooper
@alexandre_benekowski wrote:
... i´d like to count numbers of characters before "+" and after "+":
ex:
1+25
answer
1 and 2
100+25.00
answer
3 and 5
(setq str "1234+56")
Then:
(strcat
  (itoa (setq pre (vl-string-position (ascii "+") str)))
  " and "
  (itoa (- (strlen str) pre 1))
returns:
"4 and 2"
Kent Cooper, AIA
Message 8 of 8
I Kent!!!
thank you so very much!!!
It work!!!!
