(defun C:lM (/ searchString basept ss n totalTextEntities)
; Set the search string to "muthu"
(setq searchString "muthu")
; Prompt the user to enter the base point
(setq basept (getpoint "\nEnter base point for marking Lines: "))
; Initialize a variable to count the total number of text entities found
(setq totalTextEntities 0)
; Iterate through the layers in the active document
(vlax-for lay (vla-get-layers (vla-get-activedocument (vlax-get-acad-object)))
; Check if the layer name matches the search string using wildcards
(if (wcmatch (vla-get-name lay) (strcat "*" searchString))
(progn
; Get the selection set of text entities on the current layer
(if (setq ss (ssget "_X" (list (cons 8 (vla-get-name lay)))))
(progn
; Process each text entity found on the current layer
(setq n (sslength ss))
(repeat n
(entmake
(list
'(0 . "LINE")
(cons 10 basept)
(cons 11 (cdr (assoc 10 (entget (ssname ss (setq n (1- n))))))
; Increment the total count of text entities found
(setq totalTextEntities (+ totalTextEntities (sslength ss)))
; Display the total count of text entities found
(alert (strcat "Total text entities found: " (itoa totalTextEntities)))
(princ)
).i want serach layer name contain muthu string count and find mark with line error is malformed list on input
how to solve this problem
