Malformed list on input
Message 1 of 9
I used TD.lsp to insert multiple typical details without having to go through the insert screen everytime. I tried to update it so I could specify what details I wanted instead of having to go through the library. Now that I've added a conditional, I get an error message. Please help.
Accepted solutions (3)
Replies (8)
Message 2 of 9
hak_vz
Try this
(defun C:TEST ( / k) ;TYPICAL DETAILS
	(initget 1 "CF GB CS CB CM BW W PR SB ND CD MS TC PS")
	(set k (getkword "\nWhich table are you using? [CF/GB/CS/CB/CM/BW/W/PR/SB/ND/CD/MS/TC/PS] :"))
	(cond
	  	((= k "CF")
			(Foreach itm
				'( "N:\\CAD\\AutoCad Blocks\\Details\\Block\\"
					"N:\\CAD\\AutoCad Blocks\\Details\\Concrete\\"
					"N:\\CAD\\AutoCad Blocks\\Details\\Foundation\\"
					"N:\\CAD\\AutoCad Blocks\\Details\\Misc\\"
				(foreach dwg (LM:listbox "Select drawing Files" (vl-directory-files itm "*.dwg" 1) 1)
      					(command "_insert" (strcat itm dwg) pause "1" "1" "0")
	  	((= k "W")
			(Foreach itm
		 			"N:\\CAD\\AutoCad Blocks\\Details\\Truss\\"
		 			"N:\\CAD\\AutoCad Blocks\\Details\\Wood\\"
Miljenko Hatlak
Message 3 of 9
Awesome! It lets me load it, but now my condition doesn't work. Another nut to crack.
Message 4 of 9
pbejse
The error comes from this line
Change it to
(setq k (getkword "\nWhich table are you using? [CF/GB/CS/CB/CM/BW/W/PR/SB/ND/CD/MS/TC/PS] :"))
And you are missing a  number of  parenthesis on your cond statement
(Cond
 	( (= k "CF")(foreach ...
		      (foreach ...)
	 ( (= k "W") (foreach ...
		       (foreach ... )
	 );cond
Here is another way to add more options
  (setq details "N:\\CAD\\AutoCad Blocks\\Details\\"
	library '(( "CF" . ("Block" "Concrete" "Foundation" "Misc" "Foundation"))
		  ( "W"  . ("Block" "Misc" "Truss" "Wood"))
  	(if
	  (setq f (Assoc k library))
	     (foreach itm (cdr f)
	       (if (findfile (strcat details itm))
	  	(foreach dwg (LM:listbox "Select drawing Files" (vl-directory-files (setq path (strcat details itm "\\")) "*.dwg" 1) 1)
      					(command "_insert" (strcat path dwg) pause "1" "1" "0")
  (princ)
HTH
Message 5 of 9
hak_vz
	(cond
	  	((= k "CF")
			(Foreach itm
	  	((= k "W")
			(Foreach itm
I've had some troubles with reaching forum, so my intervention to change set to setq didn't pass through. This will probably work and here you have solution from @pbejse
Miljenko Hatlak
Message 6 of 9
Last question. I run this, the condition works, but for some reason in my dwg's don't show up in the list box. It used to work on my 2016 autocad, but now I'm on a computer that uses 2014. just checking if this works for other users.
Message 7 of 9
hak_vz
@Anonymous
It should work just fine with any version of a Acad including ver 2014 or similar programs that use visual lisp. If you answer on type of structure with correct key value it shows DCL dialog (keywords "CF" "W").
Execution is a bit awkward since if you lookup more than directory since code jumps from folder to folder and DCL title is always equal to "Select dwg". What if each folder has files with same name?
Miljenko Hatlak
Message 8 of 9
pbejse
Only time LM:listbox is empty is if there are no drawing files found on specified folder.
You should modfiy TD UPDATE.LSP to check for valid files and show the current keyword selection and folder on the list box title.
(if (setq DwgFiles (vl-directory-files itm "*.dwg" 1))
	(foreach dwg (LM:listbox (strcat "Select Drawing(s) | " k " | "
					 (vl-filename-base (vl-filename-directory itm)))
		       		DwgFiles 1)
HTH
Message 9 of 9
thanks for all the help. Turns out the file path on this new computer is different from my last one. Just used findfile to get the path and works like a dream now.
