Making text extrudable solid
I am trying to put initials onto a slightly curved but otherwise smooth surface of a 3D solid. Is there any way to:
a) create vertical text along a curved line
b) make this text a solid that can be extruded or pushed in to create an "engraved" look on the slightly curved solid
clindner
As for the curved text, see if the ARCTEXT command (an Express tool) helps. You could combine this with a text style that's vertical to create your desired vertical text effect.
Re extruding text: Try the TEXTEXP command (also an Express tool) to explode the text. You can then convert to it into polylines or regions and extrude to solids. I've also "printed" text to a DXB file to "explode" it.
HTH.
Please use the Accept as Solution or Kudo buttons when appropriate
Chris Lindner
CAD Technology Consultant @ onebuttoncad.com
AUGI Board of Directors
schulz8NPAP
See the attachment - engraving linework onto REVSURF's
Regards
Jochen
www.black-cad.de
ronjonp
Another great tool to turn text into line work is Sean's T2G code .. quite a bit more accurate than the express fools version :).
