Making only the text visible on the screen into mext
k005
Advisor Advisor
k005
Hello friends;
Can we convert text objects visible on an object approached with Zoom Window to mtext without selecting them?
*That is, to make mtext only the texts that appear in the zoomed (or zoomed) part... without selecting them...
Thanks.
Kent1Cooper
A routine could work with the VIEWCTR and VIEWSIZE System Variables to determine the top- and bottom-edge Y coordinates of the current view.  I'm not aware of a way to determine its left- and right-edge X coordinates, to be able to define a selection window, but maybe someone knows....
Kent Cooper, AIA
komondormrex
hello there,
check this out
(defun c:visible_text_mtext (/ screen_height screen_size_list view_center aspect_ratio actual_screen_size_list actual_screen_llc_urc_list text_sset)
	(setq screen_height (getvar 'viewsize)
	      screen_size_list (getvar 'screensize)
	      view_center (getvar 'viewctr)
	      aspect_ratio (apply '/ screen_size_list)
	      actual_screen_size_list (list (* aspect_ratio screen_height) screen_height)
	      actual_screen_llc_urc_list (list (mapcar '- view_center (mapcar '* '(0.5 0.5) actual_screen_size_list))
					       (mapcar '+ view_center (mapcar '* '(0.5 0.5) actual_screen_size_list))
	(if (setq text_sset (ssget "_w" (car actual_screen_llc_urc_list) (cadr actual_screen_llc_urc_list) '((0 . "text"))))
		(progn
		  	(setvar 'cmdecho 0)
		  	(foreach text (vl-remove-if 'listp (mapcar 'cadr (ssnamex text_sset)))
			  	(command "_txt2mtxt" text "")
		  	(setvar 'cmdecho 1)
		  	(princ (strcat "\nTexts converted to mtexts: " (itoa (sslength text_sset))))
	  	(princ "\nNo visible texts found")
	(princ)
k005
@komondormrex
Yes. It worked. Thank you very much. In one word Super! 🤗
