Making a function run when a lisp code is loaded with appload
What I'm trying to do is pretty simple, I have a routine and I want that, when someone loads it into autocad, a pop up appears on the screen with a little explaining of what it does. I know how to do the popup, but I have no idea on how to make it run specifically when the routine is loaded, any suggestions ?
kajanthangavel
(<< Your lisp Code >>)
(alert "Lisp Load Successfully")
john.uhden
It's all about the LSP file you load.  It should be structured something like this:
(vl-load-com)
;; Define any global functions you want to use
(defun function1 (local1 local2)
   ;; blah blah
(defun function2 (local1 local2)
   ;; blah blah
;; This is the custom command you want to run:
(defun c:RUN (/ this that)
  (setq this "this" that "that")
  (function1 this nil)
  (function2 nil that)
  (command "_.dosomething")
  (princ)
;; Invoke the custom command:
(c:RUN)
(princ) ;; end of AutoLisp file
John F. Uhden
Kent1Cooper
If it's something you want to do only once, and immediately upon loading, and don't need to be able to type in a command name later to do it again, then you can skip defining it into a command and then invoking that command, and just do it directly.  The entire file could be something like this, with no (defun)'s at all:
(alert "This routine honks the horn\nand rolls down the windows.")
(setq cmde (getvar 'cmdecho))
(setvar 'cmdecho 0)
(setq
  option1 (getwhatever this that other)
  point1 (getpoint "\nLocation: ")
  option2 (getsomething "'nTell me about it: ")
  point2 (getpoint "nOther location: ")
(command
  "_.this" option1 point1
  "_.that" option2 point2 "stringA"
  "_.qsave"
(setvar 'cmdecho 1)
(princ)
Kent Cooper, AIA
