Making a file as read only.
Muhammed.OPERA
Advisor Advisor
Muhammed.OPERA
Hi everyone,
I'm trying to add some things to my lisp to make the drawing as read only but avoiding doslib arx. Smiley Sad
I have seen that code but i don't understand it and it's not working :
(DEFUN VXGETFILEINFOS (FIL / FILOBJ FILSYS RETVAL)
(SETQ FILSYS (VLAX-CREATE-OBJECT "SCRIPTING.FILESYSTEMOBJECT")
RETVAL (COND
((= (VLAX-INVOKE FILSYS "FILEEXISTS" FIL) 0) NIL)
((SETQ FILOBJ (VLAX-INVOKE FILSYS "GETFILE" FIL))
(LIST
(VLAX-GET FILOBJ "DATECREATED")
(VLAX-GET FILOBJ "DATELASTMODIFIED")
(VLAX-GET FILOBJ "DATELASTACCESSED")
(VLAX-GET FILOBJ "TYPE")
(/ (VLAX-GET FILOBJ "SIZE") 1000.0)
(VLAX-GET FILOBJ "ATTRIBUTES")
(T NIL)
(IF FILOBJ (VLAX-RELEASE-OBJECT FILOBJ))
(VLAX-RELEASE-OBJECT FILSYS)
RETVAL
Do anyone have any idea to achieve that?
Muhammed Mamdouh (OPERA)
Structural Engineer, Instructor
Facebook |LinkedIn
Scottu2
Hello Muhammad.Opera,
When the routine is called  (setq A (VXGETFILEINFOS "c:/myfile.dwg"))
The value of A should be a list of the file attributes, dates, type, size, and attribute value
The routine only displays the current file status
The attribute value? If its a number like the Osmode the single value may represent multiple conditions.
It may not be possible to change the attribute of a drawing that is currently open.
See also Changing-file-attributes-with-lisp
Muhammed.OPERA
Hi @Scottu2
Thanks a lot for that link, there i find a code that worked successfully.
Facebook |LinkedIn
Hi
I want this code which work Successfully
