Hi everyone,
I need a routine, to make every block reference as unique block in entire drawing, for use in other sofrtware. I have found a leemac script Copy or Rename Block reference, it does exactly what i need but just for one selected element. I have tried to edit it, and with some success but i have got strange error also. When i run this script first time in drawing with block i work perfectly, but when i try to run it again in the same drawing i got error with selection set. I can't figure it out why it is happening.
There are my edited script and also some simple drawing with two blocks inside. After loading a lisp to file use cb command, you will find, that routine created new definition of block with numbered definition and also deleted block reference for base block. But if u try to use cb command again it will fail right after creation of new selection set. I can't manage to run this script second time in the same drawing. If i copy this new blocks to fresh drawing and then in new drawing again run cb command it works again, but again only once. What is going on here?
