Make this lisp work in Autocad LT
DC-MWA
Message 1 of 10
DC-MWA
I have this little "franken-lisp" i have been using. We are moving to autocad LT and the vlax function are not supported.
I'm hoping someone can assist me making something similar that will work with LT.
Replies (9)
Message 2 of 10
cadffm
>>"the vlax function are not supported"
Which one?
Sebastian
Message 3 of 10
cadffm
Which one?
There are two, both are supported. Test your lisp in a new file with rectangles made by command rectang.
Sebastian
Message 4 of 10
paullimapa
All @cadffm has to do is wave his magic wand and now that lisp works in LT...give it a try.
Paul Li
IT Specialist
@The Office
Message 5 of 10
pendean
Community Legend
Community Legend
@DC-MWA Your LISP works just fine in LT2024 and LT2025: earlier LT versions did not have LISP.
BUT... it does not seem to work if your rectangles are small (returns a zero or 1).
Is that what you are seeing perhaps?
Message 6 of 10
DC-MWA
Not sure why it was not working. I looked it up and oracle told me the vlax was not supported. So my limited lisp self assumed. Shame on me.
Thank you all for your assist and wisdom.
Message 7 of 10
cadffm
For other lisps, if they not working after ACAD restart, tried in another file:
Check the lisp content for
read this (and for more informations, follow the link in my post)
https://forums.autodesk.com/t5/autocad-lt-forum/attout-attin-equivalent-for-lt/td-p/12587077
Sebastian
Message 8 of 10
ec-cad
Here's an old method that should work in LT for getting Area.
Uses (command ".area" O ent) to set system variable 'Area (for entity 'ent)
Give it a try. I'm not sure why your original code prompts for selecting polylines to
(subtract), but code shows addition ? Anyway, change as desired.
Cheers
ECCAD
(defun C:SubArea ( )
  (vl-load-com)
;; Select Outer Polyline for Area
  (setq pl1 (car (entsel "\nSelect Outer Polyline for Area:")))
  (if pl1
   (progn
    (redraw pl1)
    (command ".area" "O" pl1); set var 'area to this area
    (setq pl1_area (/ (getvar "area") 144)); Area in Sq. Ft.
    (if pl1_area
     (progn
      (setq subA 0 I 0)
       (princ "\n<<<< Select Objects to Subtract >>>>")
       (setq plS (ssget)); Select Objects to Subtract
       (repeat (sslength plS)
        (setq plx (ssname plS I)); each item
        (setq etype (cdr (assoc 0 (entget plx))))
         (if (= etype "LWPOLYLINE")
          (progn
           (command ".area" "O" plx)
           (setq subA (+ subA (/ (getvar "area") 144)))
          ); progn
         ); if
         (setq I (+ I 1))
        ); repeat
        (if (> subA 0.0)
         (progn
          (setq TotA (- pl1_area subA)); Subtract Areas from Outer Polyline
          (setq str (rtos TotA 2 2))
          (alert (strcat "\nTotal Area: " str " SF"))
         ); progn
        ); if
      ); progn
     ); if
    ); progn
   ); if
   (princ)
 ); function
 (princ)
Message 9 of 10
cadffm
Hi ,
Uses (command"
OLD LT (v2023 or older) = NO LISP or othe API
Since 2024, Lisp is available and the lisp above works.
Sebastian
Message 10 of 10
ec-cad
Should have said "that should work in 2024LT or 2025LT that support Lisp, for getting Area.
My bad.
ECCAD
