Make a list of products and quantities from a list of dotted pairs
mid-awe
mid-awe
Please help, I am having a dumb moment and becoming exasperated.
I have a list of pairs,
(("372" .  "8LG")  ("373" .  "4LG") ("374" .  "1LG")  ("375" .  "no equiv") ("376" .  "4LG") )
What I need is to total up each CDR value, then produce a new list like:
(("1" .  "1LG")("2" . "4LG")("1" . "8LG")("1" . "no equiv"))
Please help, I know this shouldn't be difficult but the solution evades me.
Thank you in advance for any help or suggestions.
ВeekeeCZ
Possibly like this
(defun test (lst / l a )
  (foreach e (vl-sort (mapcar 'cdr lst) '>)
    (setq l (if (setq a (assoc e l))
	      (subst (cons e (1+ (cdr a))) a l)
	      (cons (cons e 1) l))))
  (mapcar '(lambda (e) (cons (itoa (cdr e)) (car e))) l))
mid-awe
Thank you, I have another challenge, I am trying to use VL-STRING-SEARCH  to find "no equiv" as it is attached to the end of the unmatchable sku# like this ("5" . "J-LG-1P-25-NO-CL090-DW <- no equiv")
To adjust the code you shared I did this:
(IF (= nil (VL-STRING-SEARCH "<- no equiv" e))
(cons (cons e 1) l)))))
But of course, everything goes haywire. By haywire I mean, it takes this list:
(("9" . "J-LG-1P-50-NO-CL180-DW <- no equiv") ("8" . "J-LG-1P-50-NO-CL180-DW <- no equiv") ("7" . "J-LG-1P-50-NO-CC180-DW <- no equiv") ("6" . "5LG") ("5" . "J-LG-1P-50-NO-CL180-DW <- no equiv") ("4" . "4LG") ("3" . "4LG") ("20" . "4LG") ("2" . "4LG") ("19" . "J-LG-1P-25-NO-CL090-DW <- no equiv") ("18" . "4LG") ("17" . "4LG") ("16" . "4LG") ("15" . "10LG") ("14" . "10LG") ("13" . "5LG") ("12" . "4LG") ("11" . "4LG") ("10" . "J-LG-1P-50-NO-CC180-DW <- no equiv") ("1" . "J-LG-1P-50-NO-CC180-DW <- no equiv"))
and returned this,
(("1" . "10LG") ("1" . "4LG") ("1" . "5LG") ("1" . "no equiv") ("1" . "no equiv") ("1" . "no equiv") ("1" . "no equiv") ("1" . "no equiv") ("1" . "no equiv") ("1" . "no equiv"))
but I was hoping for this:
(("7" . "no equiv") ("2" . "5LG") ("9" . "4LG") ("2" . "10LG"))
I hope that makes sense.
Thank you for your help.
komondormrex
try the following
(defun parse_list (_list / unique_list old_member)
	(foreach _member _list (if (not (member _member unique_list)) (setq unique_list (append unique_list (list _member)))))
	(setq unique_list (mapcar '(lambda (_member) (cons _member 0)) unique_list))
		(if (setq old_member (assoc _member unique_list))
				(setq unique_list (subst (cons (car old_member) (1+ (cdr old_member))) old_member unique_list))
(setq assoc_list '(("9" . "J-LG-1P-50-NO-CL180-DW <- no equiv") ("8" . "J-LG-1P-50-NO-CL180-DW <- no equiv") ("7" . "J-LG-1P-50-NO-CC180-DW <- no equiv") ("6" . "5LG") ("5" . "J-LG-1P-50-NO-CL180-DW <- no equiv") ("4" . "4LG") ("3" . "4LG") ("20" . "4LG") ("2" . "4LG") ("19" . "J-LG-1P-25-NO-CL090-DW <- no equiv") ("18" . "4LG") ("17" . "4LG") ("16" . "4LG") ("15" . "10LG") ("14" . "10LG") ("13" . "5LG") ("12" . "4LG") ("11" . "4LG") ("10" . "J-LG-1P-50-NO-CC180-DW <- no equiv") ("1" . "J-LG-1P-50-NO-CC180-DW <- no equiv")))
(parse_list (mapcar '(lambda (element) (if (wcmatch (cdr element) "*no equiv*") "no equiv" (cdr element))) assoc_list)) -> (("no equiv" . 7) ("5LG" . 2) ("4LG" . 9) ("10LG" . 2))
ВeekeeCZ
Well, I would suggest to break down process to small steps which should make the process easier. Also added the comments to help understand. IMHO that main sort algoritmem based on an associated list - that is very common algorithm, very useful, you should really try to learn and understand.
    ;; prepare the list...
    (setq lst (mapcar 'cdr lst)) 	; make a list of second items
    (setq lst (mapcar '(lambda (e)	; clear the list
			 (if (vl-string-search "<- no equiv" e)
			   "<- no equiv"
			   e)
		      lst))
    ;; use an associate list to count unique items... '((unique-item1 . total1) (unique-item2 . total2) (unique-item3 . total3) ...)
    (foreach e lst
      (if (setq a (assoc e l))				; if item already is in the new l list
	(setq l (subst (cons e (1+ (cdr a)))		; then replace item with new one that addes +1 to total (item . (+ 1 total))
		       a
		       l))
	(setq l (cons (cons e 1)			; else add new '(item . 1) to the list
		      l))))
    ;; restructure the list to desired output form
    (setq l (vl-sort l '(lambda (e1 e2) (> (car e1) (car e2))))) ; sort the list
    (mapcar '(lambda (e) (cons (itoa (cdr e)) (car e))) l)  	 ; reverse items, convert to string: from '(item . total) to ("total" . item)
And to just fix your idea.. it's also possible..
      (IF (VL-STRING-SEARCH "<- no equiv" e)
	(setq e "<- no equiv"))
mid-awe
Thank you.
mid-awe
Thank you for the detailed answer.
(mapcar 'cdr lst)
I missed this by a mile. You are always so generous with your answer. Again Thank you.
