magnifying glass in autocad
Message 1 of 11
Hi guys,
I came up with another idea that will be very helpfull , I would be glad for help.
As you can see in the pic.
https://www.dropbox.com/s/g9v4gzrxdo17rw7/2017-04-20_10-50-17.jpg?dl=0
I want that the lisp wil magnify the cursor location in a rectangle that will apear over the cursor
By clicking on the lisp it should ask for scale to magnify , the default would be 3 times the original.
Thank you in advance.
Replies (10)
Message 2 of 11
marko_ribar
Contact Andrea from Ductisoft...
https://www.theswamp.org/index.php?topic=42964.msg482624#msg482624
(you have to be logged to access...)
Marko Ribar, d.i.a. (graduated engineer of architecture)
Message 3 of 11
Hi Marko,
It looks great
https://www.dropbox.com/s/7n8aio56ek8foqn/mvexmove.gif?dl=0
but how can I use this code?
(setq circleMVIEW nil)
(while (not circleMVIEW)
  (if (setq it (entsel))
    (progn
      (setq circleMVIEW (cdr (assoc 330 (entget (car it)))))
      (princ)
(setq newcoord '(0.0 0.0 0.0))
(entmod (subst (cons 12 newcoord) (assoc 12 (entget circleMVIEW)) (entget circleMVIEW)))
Is it a lisp?
Message 4 of 11
Yes, this is Autolisp.
The code will be executed immediately when you enter it. If you want to use it a function you have to add a first and a last line:
(defun c:my_magn_glass ()  ; you can use another name for the function
--> insert the code above here
) ; this is the last line to close the first one ...
UNTESTED!
Message 5 of 11
marko_ribar
My version is not so smooth, but it works...
M.R.
Message 6 of 11
Hi Marko,
It looks very nice, can you publish your lisp?
Thank you.
Message 7 of 11
marko_ribar
Will I get solution and kudo if I publish it... Actually it's very simple - 95 lines, everyone can write it... And I don't want to spoil Andrea's business, so I'll think of posting the code...
Message 8 of 11
Hi Marko,
Of course you'll get solution and KUDO ,
And don't worry you are absolutely not spoil Andrea's business , you are making a wonderfull service.
Thank you in advance!
Eyal
Message 9 of 11
marko_ribar
@Anonymous wrote:
Hi Marko,
Eyal
OK then... I even shortened more the code - it's now ab 80 lines...
(defun c:magglass ( / *error* polygon adoc spc s1 s2 s e b n scf pp gr p v vn ip bn loop )
  (vl-load-com)
  (defun *error* ( m )
    (if (and e (not (vlax-erased-p e)))
      (entdel e)
    (vla-endundomark adoc)
    (if m
      (prompt m)
    (princ)
  (defun polygon ( ci n / c r k a p pl )
    (setq c (cdr (assoc 10 (entget ci))))
    (setq r (cdr (assoc 40 (entget ci))))
    (setq k -1 a (/ (* 2 pi) n))
    (repeat n
      (setq p (polar c (* (setq k (1+ k)) a) r))
      (setq pl (cons p pl))
    (setq pl (reverse pl))
    (entmakex
      (append
        (list
          '(0 . "LWPOLYLINE")
          '(100 . "AcDbEntity")
          '(100 . "AcDbPolyline")
          (cons 90 (length pl))
          '(70 . 1)
          '(38 . 0.0)
        (mapcar '(lambda ( x ) (cons 10 (mapcar '+ '(0 0) x))) pl)
        '((210 0.0 0.0 1.0))
  (vla-startundomark (setq adoc (vla-get-activedocument (vlax-get-acad-object))))
  (setq spc (vla-get-block (vla-get-activelayout adoc)))
  (prompt "\nPick magnifying glass circle...")
  (setq s1 (ssget "_+.:E:S" '((0 . "CIRCLE"))))
  (while (not s1)
    (prompt "\nMissed... Pick magnifying glass circle again...")
  (prompt "\nPick moving glass circle...")
  (setq s2 (ssget "_+.:E:S:L" '((0 . "CIRCLE"))))
  (while (not s2)
    (prompt "\nMissed... Pick moving glass circle on unlocked layer again...")
  (setq s (ssget "_A"))
  (if (cadr (sssetfirst nil s))
    (setq s (ssget "_:L"))
  (ssdel (setq s1 (ssname s1 0)) s)
  (ssdel (setq s2 (ssname s2 0)) s)
  (setq e (polygon s1 36))
  (command "_.COPYBASE" "_non" '(0 0 0) s "")
  (command "_.PASTEBLOCK" "_non" '(0 0 0))
  (setq b (entlast))
  (setq n (cdr (assoc 2 (entget b))))
  (entdel b)
  (setq scf (/ (cdr (assoc 40 (entget s1))) (cdr (assoc 40 (entget s2)))))
  (setq pp (cdr (assoc 10 (entget s1))))
  (while (/= 3 (car (setq gr (grread t))))
    (if loop
      (entdel bn)
    (setq p (cadr gr))
    (setq v (mapcar '- '(0 0 0) p))
    (setq vn (mapcar '* v (list scf scf scf)))
    (entupd (cdr (assoc -1 (entmod (subst (cons 10 p) (assoc 10 (entget s2)) (entget s2))))))
    (setq ip (mapcar '+ pp vn))
    (setq bn (vlax-vla-object->ename (vla-insertblock spc (vlax-3d-point ip) n scf scf scf 0)))
    (command "_.XCLIP" bn "" "_N" "_S" e)
    (setq loop t)
  (*error* nil)
Now, you promised ab kudo and solution...
Regards, M.R.
Message 10 of 11
Hi Marko,
Thank you!! it works very good!
How can I mark this post as solution , I can't find it
Have a nice day.
Eyal
Message 11 of 11
marko_ribar
Look in the attached picture in this link...
https://forums.autodesk.com/t5/inventor-forum/please-mark-this-response-as-quot-accept-as-solution-q...
Thanks...
