Macro to put objects on a certain layer.
Message 1 of 8
I'm using Autocad 2013 OEM with WoodCadCam interface.
I want to make a macro that puts certain objects in a certain layer.
I can't use the command CHPROP or COPYTOLAYER.
Can anyone help me out here?
Thanks!
Replies (7)
Message 2 of 8
ВeekeeCZ
Why not? Have you tried .CHPROP? - note the dot.
Does it have to be a macro?
Maybe a lisp...
(vl-load-com)
(defun c:PutToLayer (/ layer obj ss i)
  (setq layer "MyLayer")
  (if (and (setq ss (ssget "_:L"))
	   (or (tblsearch "LAYER" layer)
	       (vl-cmdf "_.layer" "_n" layer ""))
    (repeat (setq i (sslength ss))
      (setq obj (vlax-ename->vla-object (ssname ss (setq i (1- i)))))
      (vla-put-layer obj layer)))
  (princ)
Message 3 of 8
dbhunia
Try this......
First make the layer current into which you want to move the selected objects.....
^C^C_select;\_change;p;;p;la;$m=$(getvar,clayer);;
Or if you enter the layer name manually then try this......By this no need to make the layer current into which you want to move the selected objects.....
Why don't use Quick select to select the certain objects and put them into the selected layer (by selecting the layer from Layers tool).......
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
Message 4 of 8
Thank you, but I can't use AutoLisp, or the command change or select.
It is an oem version. That is the thing.
Message 5 of 8
ВeekeeCZ
I see. In my understanding of OEM limits, this should work. But cannot test it.
(defun c:PutToLayerMyLayer (/ layer ed ss i)
  (if (and (or (tblsearch "LAYER" layer)
	       (prompt (strcat "\nLayer '" layer "' was not found in the drawing.")))
	   (setq ss (ssget "_:L")))
      (setq ed (entget (ssname ss (setq i (1- i)))))
      (entmod (subst (cons 8 layer)
		     (assoc 8 ed)
		     ed))))
  (princ)
Message 6 of 8
I can't use Lisp routines either.
Message 7 of 8
ВeekeeCZ
And are you even able to do that somehow manually right now?
Message 8 of 8
Of course. I can select them with my mouse and select the concerning layer, and it works. But I need a command line command to use it in a macro.
