Macro needed to speed up creating Named Views
brendon_butler
Message 1 of 14
brendon_butler
Im wanting to speed up the creation of multiple Named Views.
Currently, I have the following macro working at the moment: *^C^C-view;w; (which simply runs the command and prompts for window selection, view name and then repeats).
But, I want to expand on this a little to include the prompt for pick text of a numeric text object within my drawing to return as my View name, instead of entering the number manually.
Any help would be much appreciated!
Replies (13)
Message 2 of 14
pbejse
@brendon_butler wrote:
Im wanting to speed up the creation of multiple Named Views....
Why a macro?  Are you using LT?
is there an object identifying the view? ( block or polyline ) ?
Named View from Rectangle (hmsilva) <--- look here
Message 3 of 14
brendon_butler
Thanks for your reply!
I guess it doesn't need to be a Macro as such. However, I thought there might be a quick an easy way to create a command button via a Macro in CUI. Any alternative would be equally accepted.
To answer your question re object ID. Yes, there will be a single line text object (number) that will be the unique number identifier that I want as the View name.
Message 4 of 14
pbejse
I'm refering to the window view brendon. look into the link on my previous post. We can change the prompt for view name with a obejct selection.
Message 5 of 14
brendon_butler
Ahh sorry, I misunderstood!
No, I'm defining the window via 2x existing node points. That too could also be set in the command. To window using node osnap. But, not the end of the world, as I can set osnap beforehand if needs be.
Message 6 of 14
pbejse
(Defun C:namedViewSelect (/ viewnamenumber ll ur)
  (setq tlcmdecho (getvar "cmdecho"))
  (if
    (and
      (setq viewnamenumber
	     (Car (entsel "\nSelect string for numer prefix: ")
      (setq viewnamenumber (Cdr (assoc 1 (entget viewnamenumber))))
      (numberp (Read viewnamenumber))
      (setq ll (getpoint "\nPick lower left corner: "))
      (setq ur (getcorner ll "\nPick upper righ corner: "))
     (command "view"
	      "_W"
	      (strcat (vl-filename-base (Getvar 'dwgname))
		      "_"
		      viewnamenumber
	      ll
	      ur
Message 7 of 14
brendon_butler
That's pretty good. But, it's including my dwg name as a prefix, which I don't require. Can this string be removed to only have the selected text value only?  It otherwise works very well, thank you!
Message 8 of 14
pbejse
  (if
    (and
     (command "view"
	      "_W"
	      viewnamenumber
	      ll
	      ur
Message 9 of 14
brendon_butler
Perfect! Thank you kindly.
Message 10 of 14
pbejse
You are welcome
Cheers 👊
Message 11 of 14
brendon_butler
Sorry, one more thing I just realised I need it to do. I need the command to repeat.
I thought I'd simply just add an asterisk in front of my command macro for this to work (*^C^C_namedViewSelect;)
But, the command doesn't run at all with this added.
Do you have a fix for this?
Message 12 of 14
pbejse
change the IF to WHILE
  (if
    (and
TO
  (while
    (and
	     (Car (entsel "\nSelect string for numer prefix: ") ...
Message 13 of 14
brendon_butler
That's great, thank again!
Message 14 of 14
timothy_crouse
Hello, I was pointed here from another thread
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/need-a-lisp-to-create-named-views-an...
I need to create multiple named views all with the same category:
"FN-[start number]", "FN-001", "FN-003" . . . .. . "FN-[end number], [category name]
Any chance someone could modify the lisp in this thread to do that?
Thank You
-Tim C.
