Macro for rotating text to a line
allywhite666
allywhite666
I would like a macro that will rotate any text to a line with just two clicks.
At the moment I am selecting the text and then rotate,
then I have to pick a base point,
then press R for reference and select the two bottom corners of the text,
then I have to press P for points to pick two points on the line I want to align it to.
Does anyone have a macro that I can assign to a short cut key and just select the text and then the line, or even just select the text and then two points on the line, but would prefer the first.
I appreciate any help you guys can give me.
Thanks Heart
_Tharwat
use align command and that is less in steps than the one you are describing .
3wood
Please try TORIENT command in Express Tools. It does exactly what you want.
allywhite666
Thank you both for your help, the TORIENT command is the solution I was looking for.
