Macro Button to save as DXF and close file without saving to DWG
B_Bevelander
Message 1 of 14
B_Bevelander
I usually extract DXF's from my Inventor Enviroment and edit them in AutoCAD 2016 to tidy them up. This happens quite often and when i wish to save the edit DXF, it prompts me with a save screen, I need to reselect DXF 2004 version and press enter and comfirm in wish to override the file.
To make my life a bit easier I created a button in the Customize User Interface called 'Save as DXF' with the following macro:
+Saveas (save the file as without prompting a pop-up screen)
F (save it as a DXF)
2004 (save it as a 2004 version)
thats as far as I've gotten, as it then prompts me with a screen anyway to the select the file name.
I wish to just keep the current filename and just press Enter basicly, then a last prompt comes to ask wether im sure I want to override the file, resulting with a Y for choosing Yes.
Is there a way to build these last 2 steps into the macro itself?
Replies (13)
Message 2 of 14
ВeekeeCZ
Edit: You're not using LT, right? If you do, stop reading here.
Try this.
If the is no dxf yet, no prompt for you.
If the dxf exists, you're prompted for a name. If you confirm the same one, it will override it.
If you cancal the name dialog, or you give a new name that exists too... then you're sent to the dialog of the SaveAs.
Try and let know.
btw the closing is a little bit issue - seems to work but it's a bit forced...
(defun c:SaveAsDXF ( / *error* name-old name-new exist)
    (defun *error* (errmsg)
    (if (not (wcmatch errmsg "Function cancelled,quit / exit abort,console break,end"))
      (princ (strcat "\nError: " errmsg)))
    (princ))
  (setq name-old (vl-filename-base (getvar 'dwgname))
	path (getvar 'dwgprefix))
  (if (setq exist (findfile (strcat path name-old ".dxf")))
    (setq name-new (lisped name-old)))
  (cond ((or (numberp name-new)
	     (and exist
		  (/= name-old name-new)
		  (findfile (strcat path name-new ".dxf"))))
	 (initdia)
	 (command-s "_.saveas"))
	((and exist (= name-old name-new))
	 (command "_.saveas" "dxf" "_version" "2004" 16 (strcat path name-new) "_Yes")
	 (command "_.close") (command))
	(T
	 (command "_.saveas" "dxf" "_version" "2004" 16 (strcat path (cond (name-new) (name-old))))
  (princ)
Message 3 of 14
B_Bevelander
Doesn't seem to work, when I run the command, it stops at the 4th line (5th if you count the empty one)
Not sure if this is effected by the version im running? 2016.
Message 4 of 14
ВeekeeCZ
Not sure... try this.
    (princ))
  (setq name-old (substr (getvar 'dwgname) 1 (- (strlen (getvar 'dwgname)) 4))
	     (and exist
	 (initdia)
	(T
  (princ)
Message 5 of 14
B_Bevelander
Still same problem occurs, see attached file.
Message 6 of 14
ВeekeeCZ
Save the code as *.lsp file and drag-and-drop it into drawing.
Read THIS
Message 7 of 14
B_Bevelander
So there's no way to do this with a simple macro in a command like I initually tried?
Message 8 of 14
Moshe-A
@B_Bevelander
here check this cuix macro:
[Save to DXF 2004]^c^cDxfout;;y v 2004;;
enjoy
moshe
Message 9 of 14
B_Bevelander
That works only when I open a dwg to export it to DXF, yet when i open it as already being a DXF it gives me an error message:
EDIT: Ok with the help from previous post of @Moshe-A , changed my own code to: +Saveas F 2004 ;;; y
This seems to work for both DWG and DXF to save them as DXF in the same folder. If it already is a DXF, it overrides it, if its a DWG it creates a DXF.
Thanks for the help.
Message 10 of 14
Moshe-A
your are welcome
Notice (for next time)  when closing a thread make sure you credit the right support guy 😀
Message 11 of 14
hansDPQMN
(command "_.close") (command) you can use
(command "_.close" "n") instead for closing without saveing to dwg
Message 12 of 14
sri87
Observer
Observer
HI
I need to change the path of the dxf  location can i get updated code
Message 13 of 14
cadffm
you did not 'reply to', we don't know if you are talking about the lisp or the menumacro!?
For Lisp code:
You want to use a fix path?
Change
To
path "D:/Test/"
Or to a sub folder of your drawing file folder?
path (strcat (getvar "DWGPREFIX") "myfolder/")
HTH
Sebastian
Message 14 of 14
sri87
Observer
Observer
Thank you for your Response.
I am new to LISP programming.
Need LISP program to save current opened file to DXF & PDF.
to the location. "C:\PLOT\dxf"
could you share the LISP code for .dxf and .pdf  from DWG opened file
DWG-->DXF-->pdf.
Thank you
