Lwpolyline fillet and join
k005
Advisor Advisor
Message 1 of 11
k005
Hello friends, I want to fillet and join 90 degree lwpolyline objects as I have given in the attachment.
The relevant example is attached.
Thanks in advance to the helpful friend.
Accepted solutions (4)
Replies (10)
Message 2 of 11
Moshe-A
@k005  hi,
What is special with these lines/plines? you can draw a rectangle on top.
Moshe
Message 3 of 11
k005
Hi
My goal is not to draw a rectangle. Using existing...
Message 4 of 11
Sea-Haven
Have a look at Lee-mac bounding box multiple objects, it will give you the diagonal corners of all the lines, then make a rectang.
Message 5 of 11
k005
I looked at the Lee mac page. But I couldn't see it...
Thank you very much. It's okay. @Sea-Haven
Message 6 of 11
Kent1Cooper
When they form a simple orthogonal rectangle, try the DBBM command in DrawBoundingBoxMultiple.lsp, >here<.  It is probably pretty much equivalent to the other suggestion, but if you can't find that....
Kent Cooper, AIA
Message 7 of 11
k005
It got much better. Thank you.
@Kent1Cooper
An addition is required, it should delete the old selected objects. Let the newly created rectangle remain. Can we do this?
Message 8 of 11
Kent1Cooper
@k005 wrote:
.... it should delete the old selected objects. Let the newly created rectangle remain. Can we do this?
That's a very limited circumstance to have the selected objects all lie along the path of the resulting rectangle and that one would want to remove them [not envisioned in the writing of the routine], but yes, that can be done.  Replace this line:
  (command "_.rectang" "_none" (trans LL 0 1) "_none" (trans UR 0 1))
with this:
  (command
    "_.erase" ss ""
And consider changing the command name and prompts.
Kent Cooper, AIA
Message 9 of 11
k005
It was very nice. Thank you. @Kent1Cooper
Message 10 of 11
marko_ribar
Still, I'd here add choice to choose between 2 options (to retain selection, or to remove it like you wanted)... Perhaps that's the reason why @Kent1Cooper haven't edited his solution... Anyway, to me it seems to have sense to let the user decide how to act... So here is revision I took... Note that (ssget) now has mode "_:L" since only entities on unlocked layer(s) can be relibaly erased like you wanted, and beside that I, and perhaps some other user, predominantly work with unlocked layers...
DrawBoundingBoxMult.lsp [command name: DBBM]
To Draw the Bounding Box around Multiple objects. Finds overall extent
of object(s) selected, and draws a Rectangle around that collective box.
Works in non-World UCS if XYZ axes parallel to WCS [i.e. origin may
  be different but with same orientation].
Kent Cooper, last edited 1 February 2017
(defun C:DBBM ( / ss minpt maxpt eLL eUR LL UR ch ); = Draw Bounding Box, Multiple
  (or (not (vl-catch-all-error-p (vl-catch-all-apply (function vlax-get-acad-object) nil))) (vl-load-com))
  (prompt "\nSelect entities to Draw the Bounding Box around them all...")
  (if (setq ss (ssget "_:L"))
    (progn ; then
      (repeat (setq n (sslength ss))
        (vla-getboundingbox (vlax-ename->vla-object (ssname ss (setq n (1- n)))) 'minpt 'maxpt)
        (setq
          eLL (safearray-value minpt)
          eUR (safearray-value maxpt)
          LL (if LL (mapcar (function min) eLL LL) eLL)
          UR (if UR (mapcar (function max) eUR UR) eUR)
        ); setq
      ); repeat
      (initget 1 "M reMove T reTain")
      (setq ch (getkword "\nDou you want to reMove selected objects or reTain them [reMove/reTain] : "))
      (if (or (= ch "M") (= ch "reMove"))
        (vl-cmdf "_.rectangle" "_non" (trans LL 0 1) "_non" (trans UR 0 1) "_.erase" ss "")
        (vl-cmdf "_.rectangle" "_non" (trans LL 0 1) "_non" (trans UR 0 1))
    ); progn
    (prompt "\nNothing selected."); else
  ); if
  (princ)
); defun
HTH.
M.R.
Marko Ribar, d.i.a. (graduated engineer of architecture)
Message 11 of 11
k005
Yes, it is much better to use it this way. Thank you. @marko_ribar
